Mitsubishi WD-52825 52 in. Rear Projection HDTV Television
Problem for Mitsubishi WD-52825 52 in. Rear Projection HDTV Television
CAN SOMEONE PLEASE HELP ME
By JERZEY on Dec 14, 2008
mitsubishi 52 inch dlp hd television WD 52825 AND THE LAMP LIGHT IS BLINKING PUT IN A NEW ONE AND STILL NO LUCK I CHECKED ON HERE AND I CANT FIND WHERE THE 3300UF 35V CAPS ARE AT ON THE BORED I LOOKED ON THE POWER BORD AT THE 1000UF 16V CAPS AND THE ARE NOT LEEKING OR SWOLLEN ON THE TOP SO IM HOPING ITS THE 3300UF 35V BUT CANT FIND THEM CAN SOME PLEASE HELP ME I CANT AFORED TO BUY SPECS ON IT CAN SOMEONE EMAIL IT TO ME OR TELL ME WHERE IT IS AT AND WHAT DOES PWB, FMT and DM MEEN IF I KNOW WHAT THEY MEEN IT MAY HELP ME SUM IS THE PWB THE POWER BORD? BUT ANYWAY I AM TRYING TO FIX IT FOR MY WIFE FOR XMISS AND I NEED SOME HELP CAN SOMEONE PLEASE HELP!!!!!!!
Best Solution
posted on Dec 29, 2008
Helpful)
ima_rm2000
Rank: Guru
Rating: 88%, 164 votes
the 3300uf 16vdc caps are on the left side of the power supply board. the 1000uf caps were on the right side.
Was this helpful?
Yes
No
Solution #2
posted on Jul 07, 2009
Not Rated)
ectech21
Rank: Apprentice
Rating: 0%, 0 votes
mitsubishi wd-52825, replaced the lamp and there is still red lights blinking. any ideas?
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD-52825 52 in.
Questions and Unsolved Problems for Mitsubishi WD-52825 52 in.
Do you recommend Mitsubishi WD-52825 52 in. Rear Projection HDTV Television?
Answer
Answer
I need a TV code that allows us to use our phillips remote with full function
Answer
Model WD52825: No sound when connected to ANT-1 which is local digital TV or to TV hard disc. . Had... (More)
Answer
My tv is off with a blinking light, when I turned it on, there was no image in the screen but there... (More)
Answer
Picture won't hold on screen. Jumps up and down and does not hold.
Answer
replaced the bulb with my old one and still have shaking line for picture. I wouldnt think the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-52825 52 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
