Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
Need some advice
My bwa711 is hooked up to my ps2, it requires the dns from the router, I need to get the dns, or at least the tech support number, if any help would be available, I would be greatly appreciative
  • will powell Mar 13, 2007
    thank you so much, it worked perfectly, I've been trying to get on for several days now, and was finally able to get online today, thank you so much!!!!!
  • Anonymous Nov 03, 2007
    Do you know where I may locate a drive for the BWA711 Wireless Router?
    Problem Solver:
  • 10 Answers
If you jus need the dns ip, then you need to log into your router page and check waht dns ip is assingned in there. if you jus want to chnage the dns , you can use 4.2.2.2 and alternate dns 4.2.2.3 if this issue still persists tell me the problem in more detail i m looged in to yahoo n msn messenger thru samra101......... take care -- samrat
Posted on Mar 13, 2007
I hooked my linksys E1000 Router to Samsung 3d TV (Wired), but the TV doesnot detect the internet speed, on my laptop (Wireless) is 144Mbps.
you may need to sign in manually,those tvs sometimes dont pick up dns addresses of routers automaticallty
plug in your cable into your laptop
go to start/accessories/command prompt
type in ipconfig
scroll up till you see ethernet
take down your ip4 address,itll look something like this xxx.xxx.xxx.xxx (change the last number to something in the range of 1-250) your subnet mask ad default gateway
plug back in your line to your tv,go to manual enter settings
enter in your ip (with the number changed at the end) your subnet mask and your default gateway number for your dns/gateway if required
if you need more help try customer service on the samsung american site,theyre really good at answering any quick email queries :)
Mar 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Need drivers for blitzz bwa711 wireless firewall router
Router doesnt require driver to be installed on a computer to work. For getting into the settings or web configuration page type http://192.168.1.1 on the address bar of Internet explorer or any available web browser and you can configure it.
Jan 22, 2010 | Blitzz Technology BWA711 Router...
I still have connection to the internet through my cable box, but when I connect through my bwa711 wireless router I cannot get out to the internet; what do I need to do? Connected directly to the cable...
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
Jan 09, 2010 | Blitzz Technology BWA711 Router...
I can't connect to the internet with my new computer. I bought a new computer. I can connect with my old computer but my new says limited connectivity. it is password protected and i entered the password...
Make sure your new computer is set to automaticly obtain ip settings.
If thats not the problem, I would turn off the wireless security for a moment and see if you can succesfully connect then.
Jan 01, 2010 | Blitzz Technology BWA711 (B3WL000900)...
Set up password on blitzz bwa711 router
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
Nov 25, 2009 | Blitzz Technology BWA711 Router...
Getting Blitzz BWA 711 wireless router configured in my computer
Hi I need the router settings for BWA711 do you know what it is . Thank you, Linda
tnlmyers@comcast.net
Dec 24, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
How to make Blitzz BWA711 Router secure?
The minimum security will be WEP, so the wireless receivers on your pc should match the type of encryption. To give you WEP you select security in the routers menu and choose yourself a mixture of 6 pairs of letters and numbers in any column from 1 to 6 if it gives you 6 options. Once the letters and numbers are chosen, note down the chosen leters and numbers, and enable wep and restart router. Now go to your pc's and and go to the software you use for the recievers and select WEP. You will probably have to tell the programme whether you are on a 'Shared network key' or an 'Open network', depending on your network type (try both until one works if not sure). It will then ask for the numbers and letters you chose and wrote down, enter these and click apply and restart system. The pc's should now connect to the router. Some wireless laptops are unable to recognise WPA type security or similair so WEP is better than nothing.
Jan 29, 2007 | Blitzz Technology BWA711 Router...
No connection or limited connectivity
It may be that you have to set the router to enabe DHCP, as this will give your pc an automatic IP address. The original address settings will be different than that of your router, so go into your wireless network card properties and ensure that obtain IP adress automatically is enabled. You may also need to run the dns flush; Click Start>Run, then type ipconfig /flushdns then press enter.
Jan 06, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
52 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
didi2005
JP Services
JP Services
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
