Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
It won't print without all the cartridges.
Some of the ink cartridges are run out and it won't let me print only in black, which hasn't run out. It keeps showing me to get a new one and how to put them in. I already know all that. I just want to print in black. Do i need all the ink colours to do that?
    Problem Solver:
  • 15 Answers
Unfortunately, Yes... This is usually caused by the print driver but is sometimes hardcoded into the device itself. Typically you can still use the copier function with other empty cartridges but not the print option from your PC. There are some work-arounds with Epson devices. However, with a brother device there is no known workaround at this time.
Posted on Dec 14, 2008
  • Rob Hufault
    Rob Hufault Dec 14, 2008
    I have one 'unconfirmed' possible solution. Give this a try before giving up:
    1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
    2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
    3. Select the Color tab, then select the Print in grayscale option.
    Hope it helps Kristin!
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic.
You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow.
I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
Mar 13, 2012 | Canon Pixma MG5220 InkJet Printer
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
