Question about Toshiba Satellite U305-S7477 Notebook
Toshiba sat 305 s7477 shut down while on the net,will not restart
My son was on the net & the laptop just shut down no warning !!!nothing when you press the main power on button,i tried diff power lead no joy ,its only 1 year old. anyone got any suggestions pls
  • cuno Dec 14, 2008
    just removed battery again & put it back while playing around with the power jack it just came back on ????????happy days !!! did all that earlier today was getting nothing maybe the power jack is a bit faulty.many thnks for your reply
  • Kevin Nelson May 11, 2010
    Can the battery be removed and checked for a charge? The power jack may have been damaged and the battery was not receiving current.
  • 136 Answers
In that case have the jack checked at a good computer shop. You need to have the jack resoldered as soon as possible.
Posted on Dec 14, 2008
My wireless icon displays as not connected even though I am currently surfing the net
Shut down the computer, unplug, remove battery, plug in, reboot.
Jan 19, 2013 | Toshiba Nb 305
How do I reset my Toshiba notebook 305 to factory
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Dec 28, 2011 | Toshiba Office Equipment & Supplies
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
Jun 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
No Audio output device is installed
Go here "" to the toshiba website and download the correct driver.
Feb 22, 2009 | Toshiba Satellite U305-S7477 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite 5105-s501 Restarts Windows then shuts down intermittently
Yes it could be, the notorius GeForce2Go is a replaceable card on that model. I have seen, lines, blurry text, and Boot loop issue caused by it. Be warned, the replacement card is expensive.
Cheaper & better finding a complete laptop with busted screen.
and removing the card only. Then you will also have other spare parts.
Dec 11, 2007 | Toshiba Satellite 5105-S501 Notebook
Toshiba Satellite U305-S7477 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
