SOURCE: what Bosch super 4 spark plug fits a Ford Focus 1.6 zetec.
my advise don't get those, they don't work as well as you think they do.
if you think about it if they are so much better why don't drag racers use them?
because they actually block the ignition point.
just get the factory style plugs and you will be better off.
SOURCE: no sprk
this sounds like a computer related problem for the vehicle
the electronic spark system is not getting the signal from the computer to keep its self in flaux check the spark plug houseing unit this can be done with an omh tester to make sure that its getting continuity
the other thing is make sure you that your spark plugs wires are firmly pressed into position on spark and spark plug houseing if there not seated they wont fire
make sure capasitor is not faulty these tend to ware out
SOURCE: what are the spark plug settings for a 1.8 zetec engine
you can set the gap by using the new spark plug casing papar thikness.try it and it will work
SOURCE: how to change the spark plugs on a 1.6 zetec ford
get a plug spanner (more a socket than a spanner) and after removing the plug lead, use the spanner to remove the plug. Do one at a time so you dont get the leads mixed up or it will not start.
