CPU fan that cam togther with my CPU has 3 pin conector, but the motherboard has 4 pin Conector. That dosent sems to work ut
  • 2,992 Answers
The extra pin on the motherboard is for a speed sensor connection which your fan does not have. The plug on the fan cable has two plastic tabs which fit over a tab on the motherboard connector. Just line the tabs up and the plug will fit properly. The fourth pin on the motherboard just won't be used with your fan.
Posted on Dec 14, 2008
Hello, I'm replacing my dell 530s power supply with a 350w. Porblem is, the fan will run with the 4-pin disconnected, but nothing when connected.
as you said when the 4 pin conector is connected thefan just spin one time and stop theat means the power supply section in the motherboard is not working you will have to take the motherboard to a chiplevel service engineer the FET in your motherboard has been fried you need to change them
Jul 02, 2011 | Dell Inspiron 530s Desktop Computer
Only monitar on off probleam sx280 not cpu only desktop.
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 28, 2011 | Computers & Internet
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
How can i find wheretoplug the on off botton in a epia ml6000 ea motherboard
I noticed this is a very small motherboard, so the control panel conector may be not identified. I just see a 16 pin conector by the lower left corner, below RAM bank and among IDE conectors and PCI slot. Try to short those pins and see if it powers on. You may begin by pins 1 and2, etc. The pin 15 should be where one is missing.
Jan 27, 2011 | VIA EPIA ML6000EAG Motherboard
My computer want come on with the power the light is on on the back of the tower but it will not come on when i push the power button
you need to check the SMPS first remove the 24 pin conectior to the motherboard from the smps and short the green and black pin if the SMPS fan is working there is no problem in the SMPS conect tthe 24 pin conector to the motherboard then remove the 4pin conector from the motherboard from the smps and switch on the computer of the computer fan is working you have froblem with *********** board
Jan 17, 2011 | HP 1GHz Compaq/ Desktop Computer (RB1GPKG)
System won't post with the 12 V cpu power plug connected (only runs for about 5 sec)
switch off the system and remove the processor heat sink and the processor clean them with a clean cloth now insert the processor in the socket then apply athin layer of heat sink compund to the processor and fix the heatsink tightly in the socket an drmove the memory card and clean with clean soft cloth and insert them and restart the computer if the problem still presists change the processor with any sutable for the socket and check if the problem still presits remove the f pin conector from the smps and switch on the computer if the processor fan is working properly then switch off the computer and recontct the four pin conector and switch on if the processor fan just initate then you have problem with motherboard
Dec 28, 2010 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
no run sistem? well if you talking about OS.or nothing display on monitor but the cpu work, check the conecction between monitor and parallel conector on cpu, video card,cpu fan. power supply.
those are critical parts.
Nov 18, 2007 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
