Question about Hotpoint HSS25GFP Side by Side Refrigerator
Stopped cooling clicks constantly and regularly, fans move (jump slightly) minimally and concurrently with the clicks.
    Problem Solver:
  • 10 Answers
MOST LIKELY CONTROL BOARD LOCATED IN REAR OF REFRIG HUGE PROBLEM FOR GE SHOULD HAVE BEEN A RECALL
Posted on Dec 14, 2008
Goodman AC blower is not working. How do I fix this problem?
You need a simple relay. But, if you want it to run and never stop temporarily, take the black wire off the relay on the board ( the wire that goes back to the 240 side of the transformer and run it straight to the speed tap from the motor that's connected to the relay. I'll help you with the relay when you get when but this will make it run provided the board or relay is bad.
May 27, 2017 | Goodman Heating & Cooling
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
How do I control fan speed?
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
The fan speed on a laptop can determine how it operates consistently and reliably.
You can slow it down or speed it up, based on the circumstances.
For instance, slowing down the fan speed may be useful in reserving processes or during a prolonged slow time.
Speeding it up is beneficial in keeping the laptop cool during ongoing use or high-traffic times. For the long term, find a happy medium for regular use, so you won't "psyche" out your computer by constantly adjusting the settings.
Click on the Start menu and select "Control Panel." Next, choose "Performance and Maintenance."
Select "Power Saver."
To slow the fan speed, locate the slider next to "CPU Processing Speed" and slide it down by moving across to the left.
To speed up the fan, move the slider to the right.
Press "Apply" and then "OK," if prompted.
Hope this helps
Nov 08, 2012 | Lenovo IdeaCentre Q150 PC Desktop
Freezing and ice build up stopping fan.
hi,
you could buy a spare cover and experiment with it (the one you constantly have to take off) cut it with a hacksaw blade or bend it slightly with a heat gun so the air from the fan moves in a different direction slightly. I sure wouldnt want to be working in GE's design department and have to be responsible for a huge design flaw like this. Usually GE's are trouble free.
jm
May 26, 2010 | GE Profile PDS20SFS Bottom Freezer...
198 mercury sable cooling fans motor
Cooling fans ( on radiator ) only come on when the engine reaches a certain (hot) temprature. There is a temp sensor threaded into the radiator end reservoir that switches a relay off and on that runs the fans. Either the temp sensor or the relay is probably bad. Normally , those fans will not be on if the car is moving , the air flow from just driving is sufficient to cool the rad. If you stopped and idled for a while , eventually the rad would heat up enough for the fans to come on.
Mar 31, 2010 | 1998 Mercury Sable
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
My car overheats constantly, there is a slight crack in the reservoir, but we sealed it... but the fans don't turn on!
You may need to replace cooling fan motors, but first you might want to swap cooling fan relays to see if relays are bad. hope this helps.
Jul 11, 2009 | 1996 Ford Taurus
Toshiba 4010 is giving me a "warning, problem with the cooling system message" Machine gets real slow. How can I inhibit this message, I have it on a cooling pad?
The electrical components in a PC generate heat, and fans inside the PC help move the air to keep the components from getting too hot. Excess heat will cause the fans to run constantly, damage components, and limit the speed of the CPU. All of these problems with high power and high heat will cause applications to work slower than normal. One of the main functions of the BIOS is to monitor the temperature and adjust the operating conditions. While the sound of the fan running all the time can be annoying, it may the first clue that your PC is running as efficiently as possible. To help your PC as cool and as efficiently as possible, do one or more of the following corrective actions.
  1. Update the BIOS
  2. Keep air vents clear and clean
  3. Minimize disk operation
  4. Minimize CPU operations
  5. Check whether FAN is enabled in BIOS
Thanks Rajesh
Jul 13, 2008 | Toshiba Computers & Internet
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Hotpoint HSS25GFP Side by Side Refrigerator Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
