Question about Fisher Paykel EcoSmart GWL15
Fisher Paykel not pumping
I have a Fisher Paykel GWL15. It will run through all the cycles until it gets to rinse. The pump tries to work, but it hums for about 10 seconds, then quits and does it again...It repeats this process for about a min then beeps. I am not very mechanically inclined. So I tried to remove the pump and check that and the diverter valve. But I have no clue what they look like or where they are. So I dont want to remove random parts :( Thx!!!
  • aatmwilson Dec 14, 2008
    So I bought and downloaded the service manual.....found the pump. Pulled it out....Somehow there was a stick in there?!?!?! Guess my husband or one of the kids had it in a pocket. Hmm. Anyway. Thank you very much for your info! I appreciate it!
  • 145 Answers
The pump is down underneath the machine. The fact that you hear a HUM is a clear indicator that there's something caught in the pump. You have to tip the machine back in order to get at the pump.
If you need a factory service manual, you can get one from fisher paykel here for only 10 bucks:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=46
Posted on Dec 14, 2008
  • Greg Angeli
    Greg Angeli Dec 14, 2008
    Excellent...! Glad we could help. Happy Holidays from the FixYa crew!!
Fisher and Paykel EcoSmart GWL15 won't drain at the end of it's cycle. I put it in diagnostic mode and the got it to drain that way. I ran another cycle and it wouldn't drain on it's own again. Put it back...
Hello Robert. If you have heard any kind of squeaking or squealing or rattling while the pump was running, replace the pump. You mention a humming noise. Also a sign to replace the pump. When FP pumps fail, they will not spin at the correct speed and that is why when you run it in diag mode you can pump out the water as it runs until you stop it, but will not drain in a normal cycle. Be VERY careful when you replace the pump. Make sure you get no water in the new pump windings when replacing the pump or you will WILL take out the machine controller. Pump p/n is 479595
Apr 09, 2014 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
Oct 19, 2011 | Fisher Paykel EcoSmart GWL15
I put heavy wool items in my ecosmart Fisher & Paykel washing machine (approx 9 yrs old) and after it filled with water and drained the water, it beeped unbalance so i added something else to balance...
You should not continue to run the machine until you rectify the issue with the pump. Check the resistance of the pump's coil. It should be 7 ohms for the model GWL15. If the resistance is different, there is a problem with the pump electrically and it needs to be replaced.
Jan 12, 2011 | Fisher Paykel EcoSmart GWL15
We are using model #gwl15 fisher and paykel top load washer. When it gets to the rinse cycle it justs beeps. It won't go any further. It is not unbalanced. I've taken all of the clothes out of the...
Hi just read your posting.Now when it beeps and stops do any lights flash or come on?If they do they will be on a row of 8 lights.Starting from the far left which lights are on or flashing?Are they the 1st and 4th light or 3rd and 6th --etc--?Please look underneath the machine and look to the front right of the machine You should see your pump which should have a red or black fan on it.Turn this fan a few times and hopefully this will loosen your pump if it is jammed.If you have the pump without the fan please reply and I can guide you throe unjamming it.I think with your symptoms you have described, you might have a jammed pump.Please reply for further help.Hope this helps.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
I have a Fisher & Paykel GWL15 and I have not found what is making the squilling noise when the washer starts to fill and when it is in the rinse cycle. I previously was a appliance repairman and in GE...
More likely to be the pump. Right after it lets water in it recirculates the water. To find out start the cycle. When you hear the noise, disconnect the wires going to the pump and see if it stops. The pump is on the bottom. To get to it just tip the machine back.
Nov 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Problem draining &spinning
Get the strings coins and sand out the pump and retry
Dec 17, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel intuitive code 37
As a serviceman for 18 years I have seen this numerous times.
The fault sounds like the motor control module.. Assuming your test on the pump windings was ok..?
Nov 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
371 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
