Question about Sharp R-1480 Microwave Oven
Sharp R1480 door won't close
Door won't close, latch must be broken, taped door shut, light remains on, oven does not work. Help!!
  • Sharp Master
  • 9,086 Answers
Very much so.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
Posted on Dec 15, 2008
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Sharp microwave door will not shut and the oven light stays on continuously.
The door has a switch , probably two, that engage and disengage when opening or closing. ( a failsafe so it switches off ) when you open the door, this is the problem also like a fridge the light should go off when door is shut, it may just be stuck but Dont mess with it , clean it if its got food stuff , a mild detergent round door etc , otherwise just change microwave ,
pete
Nov 10, 2010 | Microwave Ovens
Sharp R1480 - door won't close
Very much so.
You will need the
Dec 14, 2008 | Sharp R-1480 Microwave Oven
Microwave door ...hwhen closed....oven light and fan will turn on
This is usually caused by either a bad door switch or a loose door switch mount (which are pretty simple problems to fix).
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
We have uploaded the R1480 service manual to our site here to help you.
If yours is a different model, please reply back.
You can also call them at 866-779-5835.
Dec 03, 2008 | Sharp R-1480 Microwave Oven
Door does not latch when closing on Sharp Carousel model R1480 Ser.# 221885 Microwave oven
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the internal spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here but the best place to order Sharp parts is Tritronics.
Nov 05, 2008 | Microwave Ovens
Microwave won't START!!!!!!!!!!!!
It's usually a broken tab on the upper switch holder, allowing the switch to rotate just out of position.
While replacing the switch holder is the preferred solution, using hot glue to secure the switch to the holder is much easier and quicker. Just be sure not to let the door be slammed from now on.
We have the R1480 service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Sharp R-1480 Microwave Oven
Microwave door doesn't shut
I answered this personally via e-mail (and I do not mind peopke writing me personally). I think you may have a broken tab which holds the door latch head spring in place.
Oct 19, 2006 | Sharp R-1481B Microwave Oven
Sharp R-1480 Microwave Oven Logo
299 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
