Question about Dryers
WHAT IS WEIGHT OF WHIRLPOOL DUET DRYER - PLAN TO LIFT DRYER AND PLACE ON TOP OF WASHER
  • 85 Answers
The dryer is at least 200 lbs. if there are the front load type there is a stacking kit availble
Posted on Dec 16, 2008
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Even after removing and cleaning the filter in the whirlpool elite washer, I still hear a coin like rattling sound, also the water is not draining properly. What's my next step? Mike
check the drum veins you may need to remove the top of the dryer or lift the lid to get at the screws to the drum veins. remove each one clean them out and this should solve your problem
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do i stack the washer and dryer
There are two methods, one is the dryer attaches to the top of the washer. This method requries additional pieces and/or removal of the top panel of the washer. I like this method as the additional weight helps contain the washer movement.
the 2nd method involves a stand or wall bracket. These pieces also would comonly be additional parts from the appliance manufacturer.
Nov 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do I remove the pedestal from whirlpool duet washer and dryer
The unit simply sets on top of the pedistal on the newer style.
Lift off the unit to separate the 2.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace door latch on front load washer
The following link explains how to replace a door latch on a Whirlpool Duet washer:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Some people prefer to remove the top panel of the washer and work from the top. You can try that method, if you like. The screws that hold the panel in place are located in the back of the washer. With the screws removed, the panel will slide back, then lift off. The method I provided in the link, offers the best access, though.
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400PWO: Replacement of the rear counter weight
This is a simple repair. All that should be required is to remove the back panel to access the counterweight. I've performed this repair on several occasions. Loosen the bolts that sandwich the weight between the mounting plates and the whole weight should slide out of its mounted position on the back of the tub. Insert the new weight by sliding it in place and then re-installing the mounting plates and bolts. Tighten until snug. Do NOT overtighten as you may crack the weight. I hope this helps you.
Sep 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9400PWO, Exessive Vibration
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=906440&PPStack=1
I see your problem, try this link for part info, look around for a local store or print this and write down model and serial to call and tell em you need the rear counterweight for this model.
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Dryers Logo
342 people viewed this question
Top Dryers Experts
