Question about GE (PSS26MSRSS) Side by Side Refrigerator
I havs a side by side and the top won't stay cold or freeze.
The top half is not staying cold in the refrigerator and the top of the freezer but the bottom is working fine. if I unplug the unit and plug it back in it usually kicks on for a few hours then the same thing happens. Any solutions
  • 828 Answers
Cold air being heavier than warmer air will settle to the lower levels. Check for fan motor operation inside the freezer section. If the fan is not operating you meed service. Also check for frost on the back wall of the freezer section. If the fan motor does not circulate the air frost will form on the back wall, also if the defrost system is not functioning.
Posted on Dec 14, 2008
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
Whirlpool freezer on top is cold but not freezing everything in freezer. i want to reset the unit but i don't know where the rest switch is. how do i find it or what can i do.
open ref. door look up two knobs one numbers one letters.. set the number higher makes comp. run longer and should freeze everything. the letters is a vent the higher the letter more cold air stays in freezer. ok
Feb 13, 2011 | Whirlpool GS5SHAXN Side by Side...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
194 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
