Question about Whirlpool Calypso GVW9959K Top Load Washer
Wont spin or pump out
Wont spin/pump out/or agitate--Curious if there is an online service manual or shcematics agitator locks up
  • 85 Answers
These wahers are problematic and expensive to repair. remove whirpool emblem on front and remove 1/4 screw pull top foward and up look inside of front panel and you'll see tech manual
Posted on Dec 14, 2008
My whirlpool duet stacking washer wont spin or drain. i tried to do it manually as described in my owners manual with no luck
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 12, 2014 | Whirlpool duet Washing Machines
Kenmore 110.24622300 won't spin, agitate or drain but fills
There is a coupling between the motor and the transmission for the agitator that is made of plastic and rubber. The plastic gets brittle and cracks, so it will not agitate anymore. The hum you hear is probably the motor spinning without driving anything. The pump to drain the water is also driven by the same motor. If you go online you can find instructions for how to replace the coupling. You can order them from Amazon, I found one for mine for less than $5.00. This is the most likely suspect. If you are mechanically inclined, you can replace it yourself. If not, a repairman can do it relatively quickly, but there will be a hefty charge for a service call and the labor rate it high.
Dec 12, 2013 | Washing Machines
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Whirlpool top loader agitator spins by hand (wont agitate or move the clothes)while in operation.
The agitator hub may be worn down. Go to http://www.appliancerepair.net/apnet/ and find the washer repair manual. It is relatively easy to replace and inexpensive.
Remove the agitator. The hub is a plastic piece usually connected by a bolt. Remove the hub and look on the inside of the ring. The grooves that allow the agitator to move back and forth may be worn down. Call your local appliance store or order the part online.
GOOD LUCK!!!!!
Mar 21, 2010 | Whirlpool Washing Machines
Kenmore 110 92293110 washer fills spinns NO agitate floods the laundry room when it drains
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92293110
You've described two separate problems.
1. No Agitate but it will spin and
2. Flooding
See the Whirlpool / Kenmore Service manuals for the top load, direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
1. No Agitate:
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the above Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
2. Leaking:
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
You're going to have to pull the cabinet, pump, motor and transmission to check the agitate problem anyway.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Jan 30, 2010 | Washing Machines
Washer will not spin or agitate. Pump works.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
Oct 24, 2009 | Kenmore Washing Machines
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
