Question about Jenn-Air JMC7000 Microwave Oven
Microwave Trips Breaker and Blows Fuse when not in Use
Microwave Trips Breaker and Blows Fuse Hi, just had a incident with our Built in microwave tonight. The unit was not in use and it blew the circuit breaker. Upon resetting the breaker the unit would not come back on. I removed it from the build in and took the cover to find outr the fuse was blown 125 volt 20 amp ceramic. I did not have the correct voltage fuse so just to try it I substituted a 20 amp 36 volt fuse it all I had. The unit powered up and worked fine setting on the counter. I will get the correct fuse tommorow. But my dilemma is to reinstall it with the new fuse with no rhyme or reason as to what caused the problem. I thought I would let it reamain on tonight to see if it blows again before I reinstall it. I looked around and smelt around did not see anyting burned or melted. Like I said we were not using it at the time the breaker tripped.There is a small portable TV on the same circuit that has been there all along it went out thats how we new the breaker tripped. We bought them both new( TV and Jenn-Air Microwave) at the sane time 5 years ago. Any thing come to mind for me to check before I reinstall. One more time and I will mount the fuse in a different(sattelite) location.(easy to get to!) Regards Bob Northington 816-525-2271
  • Jenn-Air Master
  • 9,156 Answers
Since the internal fuse blew, the problem has to be either a surge from the power source, or an intermittent or transient short at some point beyond the fuse. With the unit unplugged, I would first look at the varistor (surge absorber) on the control circuit board to see if it might have taken a transient. It may look charred, distorted, etc. Then I would look at the door interlock switches and mounts to see if the switches are clicking properly and if they are aligned and secure. The purpose of the monitor switch is to blow the fuse (and usually the breaker) if there is aan interlokc problem. Next would be a look at the condition of the wiring from the fuse holder all the way back to the power cord. Then just for good measure, I would test the power outlet. A toaster is a good high-current load to use. But I don't think the problem's in the wiring or breaker. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find the wiring diagram, helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 Be sure to use a proper ceramic appliance fuse that's meant for the job.
Posted on Mar 13, 2007
  • William Miller
    William Miller Mar 13, 2007
    Sorry, but I meant to add a photo of a typical varistor. It's attached now.
Hi, we have a Bosch HMT8656GB built-in microwave, and the other night (shortly after microwaving several potatoes), it shorted out and tripped the main fuse for the kitchen sockets. We've isolated it to...
Confirm that the receptacle where the microwave is plugged in is not faulty by plugging something else in the recepticle and seeing if it works or if the fuse blows. Check the power cord of the microwave for broken, frayed wires. Also check the bulb socket for broken wires. It may or may not be worth the cost of repair, depending on the repair cost verses a new microwave. There are repair parts available.
May 08, 2014 | Bosch HMT8656GB Microwave Oven
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
For some reason , my microwave keeps blowing the fuse. Every-time I plug it in , it sparks and blows the fuse/trips the breaker. I dont think its the door switch because it has nothing to do with being...
Your unit is drawing way too much power, especially before you even activate the heater & fan modules. Could be dozens of causes. First line of defense is to check the power cord for a short. Consider your expertise and unit's warranty before opening it up. Check, trace and/or replace the cord. Don't ignore radiation exposure warnings, some shields are critical.
Oct 08, 2013 | Microwave Ovens
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
Maytag MMC 5000 ADW built-in microwave...about 10 years old. Fuse blows and circuit breaker pops every couple of months...what causes this? I keep replacing the fuse, but obviously something is wrong. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There is a high draw of power in the high voltage part...probably the capacitor is going bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Microwave Ovens
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Breaker blew and when flipped back on, microwave didn't work
yes there is a 15 amp fuse that needs to be changed in behind the front control panel
Aug 21, 2009 | Whirlpool MH7140XF Microwave Oven
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
708 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
