466e 1999-does this vehicle have glow plugs as there is no light
We just bought this truck and there is no manual - is it possible to order a manual for it?
Thanks
Judy
Pioneer Service & Towing, Clinton, B.C. Canada
    Genius:
  • 1,239 Answers
Hi sir
here u can get ur pioneer truck manual http://www.pureauto-india.com/search.php?q=pioneer+truck+manual&submit=Go
Posted on Jan 27, 2009
  • 19,396 Answers
Write an email to Vander Haags , they can send you a copy of the manual:
info@vanderhaags.com
Or call them in US, here is their website.
  • Ginko
    Ginko Jan 27, 2009
    I forgot to mention that Van der Haags builds this trucks in Iowa, you can also call them at 888 940 50 30 in US.
    President:
  • 1,952 Answers
  • 13,433 Answers
I will see if one is available, can you tell me whats the brand model and year of the car you have.
I don't see that you would have included the information so I don't know which car you have there.
Uset he add a comment feature, reposting will get help from another expert.
Posted on Dec 14, 2008
Why does my rodeo diesel 2.8l 99 model when cold starts at accessories point & glow plug light stays on longer?
sounds as though the cylinder,s etc are a bit clogged up, try some diesel fuel addative,as with all diesel engines if they do not get long and regular journeys the glow plugs,injectors etc get clogged ,as the engine does not get hot enough to burn these deposits off on short stop start types of journey's . you are possibly looking at replacing the glow plugs but give the addative a try and if possible take for a long drive 2-3 hours at steady highish speed , ok to repeat the addative and long drive once more ,if no improvement will need to go into the repair shop to have the glow plugs seen to at the very least , good luck
May 12, 2014 | 1999 Isuzu Rodeo
Glow plug light flashing
the glow plug are used to heat the fuel on start up only, as a diesel uses compression instead of a spark (from the spark plug) have you try checking the connection on the glow plug, or changing the glow plugs themselves?
Dec 21, 2017 | Volkswagen Cars & Trucks
Glow plug light comes on then off
The glow plug light comes on to show that the glow plugs are warming up. You should not start the vehicle until the light turns off, as it can damage your glow plugs. The light should turn off after a few seconds while the ignition switch is in the on position. In short the vehicle is working properly.
Nov 11, 2012 | 1992 Ford F250
I have a 1998 isuzu trooper 3.1td. The glow plug light on tha dashboard stays on for as much as 10 minutes sometimes. The local garage has tried to fix this with no success. Any ideas? Can I wire in a push...
If the glow plugs are faulty,this would be the reason for the problem,they are not glowing very well,unless the glow plugs have been replaced,then the circuit from the glow plug relay is faulty,or the relay itself,
Feb 05, 2010 | Isuzu Trooper Cars & Trucks
Wait to start light doesn't come on on my 1999 ram diesel it starsts a little hard on cold mornings
The Cummins does not have glow plugs as mentioned above. It has intake heaters. I have a 99 also and it is a cold natured girl on a cold morning. You should have a block heater to plug in when it is below 40 F. The electric plug should be on the passenger side just inside grill on the hood. You can plug it in all night or a couple of hours before you are ready to go and it should help. Also, since your wait to start light is not working, the intake heaters may not be working. Check them out.
Nov 10, 2009 | 1999 Dodge Ram 2500 4WD
No power to glow plugs...relay replaced...still no power...jumped 12 v to glow plug side of relay and glow plugs then energize. Can ignition be at fault?(1999 jetta alh)
There is a big fuse in the engine room for the glowplugs.
You'll find it just near the brake vacuum cilinder under a black cap...
Hear if the glow relay ticks when you'll put power on. Does the glow light lights on?
Oct 30, 2009 | 1999 Volkswagen Jetta
99 TDI Jetta engine dies 3-5 seconds after startup.
the glow plugs probably need replacing, it seems they are not heating up the gas enough.
Apr 03, 2009 | 1999 Volkswagen Jetta
Glow plug light not going out, hard to start
Hi
Check that the glow plugs are receiving a supply voltage. I don't know if the supply to the plugs on this vehicle is common rail or individual, but if they are receiving a voltage supply then I would say that at least two glow plugs are out.
Regards
Geordie
Jun 11, 2008 | 1984 Ford F 250
1999 1/2 vw tdi jetta
glow plug relay is going out
May 30, 2008 | 1999 Volkswagen Jetta
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
