Question about GE Profile WPRE6100G Top Load Washer
GE Profile top load washer wont drain or spin
I believe that I over loaded my washer it will only agateee. I took out all the heavy items and it still will only agate it won't drain or spin. How can I fix it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
SOUNDS LIKE THE LID SWITCH IS DEFECTIVE, ITS A SWITCH THAT CONTACTS WHEN DOOR CLOSES, THEN RELEASES CONTACT WHEN DOOR OPENS. HAVE A PRO CHECK IT AND REPLACE OR BYPASS IT.............
Posted on Dec 14, 2008
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer doesn't spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 28, 2010 | GE Profile WPRE6100G Top Load Washer
My washer will not spin after a heavy load of towles????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 02, 2010 | GE WJSR2070B Top Load Washer
Washer fills with water and drains but will not agitate or spin out
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE front loading washer, WJSR2080T6WW, agitates, drains, wont's spin
might be a transmissin problem, ive seen the brake get too tight on these units to allow spin
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Oct 27, 2008 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
358 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
