Rca rs 2620 power but no audio
Manufactured feb. 2003, unit has all power functions but outputs no sound. Basic troubleshooting done, no solution. Checked fuses, fine. Any suggestions? I need a manual of RCA RS 2620 5-disk changer, radio, tape player. Can't find mine and we need help. Please send me how I can find one to my drashton63@hotmail.com Thanks...
  • Anonymous Jan 31, 2009
    All functions are working but no sound. I turned the radio off one day and the next no sound. RCA model RS2620 5 cd played with am fm and tape player recorder.
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Posted on Dec 15, 2008
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like Remotes.com to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
Jul 29, 2011 | Vizio L37 Television
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
http://www.retrevo.com/support/RCA-RS3531-manual/id/19240dj989/t/2/
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
I have a RCA RS 2620 and non of the cds play. I have a 5 cd changer
Could you be more specific with your problem? It could just be that the lens is dirty. If not, trace your signal flow and make sure everything is wired and powered correctly.
Jan 04, 2011 | Audio Players & Recorders
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
RCA RS 2620
Re-state problem please
Mar 18, 2008 | RCA RS2620 Single Cassette Deck
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
RS 2620 has power but I do get any sound
If you are not familiar with electronic circuitry, I would strongly suggest you did not try to service the unit yourself. There are many circuit functions that need to be tracked and evaluated, any one of which could be the problem or one of the problems.
Please consider taking unit to to serviced
Aug 21, 2007 | RCA RS2620 Single Cassette Deck
I had the sane problem: No audio out from any source. Although I was unable to find a schematic or service manual, I did find the defective part was labeled on the circuit board as Q401 and replaced it with RadioShack part number 276-2009 (MPS2222A NPN Transistor TO-92 case NPN silicon). This is not an exact match, but is available at most RadioShack locations for under $1 and has fixed the problem.
Dec 12, 2005 | RCA RS2620 Single Cassette Deck
132 people viewed this question
 Grubhead
Grubhead
