Question about iLO Audio Players & Recorders
Can't download music to MP# player
Everytime I try to download music to my ilo siren player it says files corrupted and won't let me delete files
  • 8,596 Answers
ILO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Posted on Dec 14, 2008
Lost ilo mp3 disk
Not sure which iLo you have but here are 2 links to download firmware Siren 512 : https://system.netsuite.com/core/media/media.nl?id=16075&c=432868&h=68a87fdefb1fe2d5903b&_xt=.zip ILO 116 Firmware https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip Here is one more link to try: http://www.rave-mp.com/support/firmware.aspx Hope you find what you were looking for here.
Jul 25, 2007 | iLO (2 GB) MP3 Player
Tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Sep 13, 2008 | iLO (2 GB) MP3 Player
My mp3 player won't download my music files
What you should try is backing up your unit, if there are songs from any other source on your player
other than the one main computer you use.
Determine whether the entire load is less than 2 GB and if so, then reformat your MP3 player to make
use of space from songs which, though deleted from your player, (such deletions only decapitate the
file header) still may occupy significant disk space which is at a premium on your player.
Totally reinstall your player and then load your music onto same, leaving some headroom (some portion
of 2 GB i.e. 100 to 500 MB) on your player to allow for streaming of your music, which will enhance your
enjoyment of same.
Apr 17, 2009 | iLO (2 GB) MP3 Player
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
Jan 10, 2009 | iLO MP3 Player
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
Jan 06, 2009 | Jwin MP3 Player
Everytime I try to load music it says files corrupted
I think the music files you are trying to load is not in a format playerble by your device or player. If you are trying to load music to your MP3 player, it must be in either MP3 or WMA format. If it is a media player like WMP or Realplayer, the file must be supported by he application.
Dec 13, 2008 | iLO Audio Players & Recorders
Corrupt filenames on my Coby mp-c591 audio/visual mp3player
Reformatting will erase the music and picture files for sure - in some instances, it can also delete a player's native formatting, which requires a firmware upgrade to resolve. It looks like you've tried quite a few methods to re-add those files - have you tried the firmware upgrade yet from Coby's website?
Jun 02, 2008 | iLO (2 GB) MP3 Player
ILO keeps disconnecting
I have the exact same player. To begin syncing DOES NOT WORK with this player, don't waste your time. When it says that you need media player 10 it really means just that. I have m.p. 11 and it did the same thing. If you don't have M.P. 10 available the best way to load music is through drag and drop or use the "send to" command in the right click menu. Also the cd is only for computers that are working on windows 98 or lower. You also will have to go in and delete each song you did sync on the player. They will behave as corrupted files and keep it from playing properly if you don't.
Oct 08, 2007 | iLO (2 GB) MP3 Player
Incorrect Format Please Reformat the Player
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Nov 28, 2006 | iLO (2 GB) MP3 Player
160 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
