Question about Epson Perfection 1670 Flatbed Scanner
No image The Scanner seems to work: the scanning light moves up and down. But there is no preview image. I have tried restarting the computer, but does not help. How do I troubleshoot the problem? Thanks Yesvee
  • 7 more comments
  • Anonymous Nov 05, 2007
    yes same exact problem don't know if this is true for you as well but my scanner has a pop up message that says document was not found please insert something basically it cant pickup that anything is there and the preview is blank white.
  • jpoff Nov 08, 2007
    I'm having same problem. I reinstalled software and latest drivers. What do you mean by enabling overlay?
  • bionicman Nov 11, 2007
    I too have been having this problem. My scanner is hooked up to my Mac running OSX 10.4.10. It first happened in May of 2007. After much troubleshooting, I finally called Epson, and while on the phone, it suddenly just started working again! Since then, it has been doing it intermittently. From what I can tell, it has nothing to do with drivers, cables, or video card drivers. It's the scanner itself that just seems to go on the fritz. Every once and a while I get lucky and I get it to work by unplugging, replugging and restarting but not necessarily in that order. I've never found "the solution". I'm actually considering just buying a new scanner.
  • Anonymous Mar 02, 2008
    Epson 1670 scanner problems
    My Epson Perfection 1670 scanner has developed problems. Made no changes to my system. (Running Windows2000.) Scanner worked fine a couple of weeks ago. Now it acts like it is scanning, lights work fine, all message screens come up as they should, only there is no image after scanning- just white. I have uninstalled and reinstalled the hardware and software, and downloaded the latest updates and drivers from the Epson website, but nothing has helped. Still getting the same results. All appear to be working fine, but no images appear after the scanning is done. Any suggestions?
  • jjohn19404 Apr 10, 2008
    Same problem ,uninstalled & reinstalled hardware & software still no image.
  • Anonymous Jun 04, 2008
    scans exact size of the picture, but is solid black.
  • Mrubio5911 Jun 25, 2008
    Tried restarting computer Scanner reads: cannot find a document, place a document and try again, (tried that) try scanning in different mode, tried Full Mode, Home Mode, and Professional Mode still comes up reading Cannot find document.
  • dtoepel Nov 12, 2008
    Scanner seems to work, but no image is generated
  • Anonymous Dec 11, 2008
    Everything works as it should, but no image appears on Preview or Scan mode.
I had the same problem and I figured out how to fix it. First I unplugged the scanner. Then I bit the cables in half. Next I hit the scanner as hard as possible with a hammer. Then I put it on the floor and jumped on it a few times. After that I covered it with gas and set it on fire. Finally I peed on it as it burned. Then I got a new scanner- an HP.
Posted on Apr 02, 2009
Same problem. I was about to buy a new scanner, I tried
Best Solution posted on Apr 22, 2008 (above) and it worked.
Posted on Jan 20, 2009
This is a standard procedure that can be varied to fix many problems. It fixed my Epson Perfection 1670 no preview image problem.
1. Disconnect USB scanner cable. 2. Download latest Epson scanner driver. 3. Run scanner driver, choosing Uninstall instead of Install. 4. Run a Spotlight search for 'Epson'. 5. Delete all files and folders related to the Epson scanner (more difficult if you have multiple Epson peripherals). 6. Restart computer. 7. Re-install Epson driver. 8. Re-connect USB scanner cable.
If there is an error saying that certain files are in use, you can use the Activity Monitor utility to shut them down.
bon chance.
Posted on Nov 08, 2008
Here's how I fixed it. Remove Epson Scan and "Scanner Software". Disconnect scanner. Unplug scanner from power. Reinstall latest driver from Epson for 1670. Reboot. XP finds hardware and runs installation, click continue anyway. Reboot again. Plug power to scanner, hook up USB...ouila!
Posted on Apr 22, 2008
Hi, i had the same problem with the blank image, i did what adrian said and i change the usb port but the problem still exist.I'll shut it down and i'll wait a wile and then i'll decide if i have to buy a new one. also thank you all for the help.
Posted on Mar 05, 2008
I had same problem. Neither the recommendations on EPSON's web page nor reinstalling EPSON's latest driver for Windows Vista helped. Then I tried Adrian's 2-step fix (above). Worked like a champ!!! thanks!
Posted on Feb 23, 2008
I had this problem also. The solution given above by Adrian worked for me. No need to wait two days. Thanks for all of your help!
Posted on Jan 29, 2008
I also had the same problem after a sudden power failure. I followed the advice to switch it off (and then to leave it off for a few days). I did not need the scanner over the weekend and fotgot about it. When I switched it back on this morning, it works fine.
Posted on Jan 28, 2008
I have exactly the same problem .
The solution found after many trials that seems to work is:
Connect the scanner ( first the power plug ,secondly the USB ) - alowing the required delay between each operation ,BUT DO THIS only after you have turned on the PC !
Adrian
Posted on Dec 26, 2007
I had the same bug these days , also tried everything with no avail . Suddenly the scanner started working .
I have 2 suggestions to give : First try the scanner on another PC . Secondly seems to me ( as a hardware engineer ) that the problem is related somehow to the USB ports , try to remove other USB devices at the same time . Good Luck to all of us
Adrian
Posted on Dec 23, 2007
As per the Solution posted by "Guest" on Nov 20th, this does appear to work. My scanner has been turned off for over a week now and I just plugged it back in and it does work. This has worked for me in the past as well, but sometimes 2 days isn't enough. As a graphic artist, waiting for my scanner to work when it "feels like it" is sort of a hassle!
Thanks for the tip Guest : )
Posted on Nov 20, 2007
I had the same problem. I found the fix for mine on another sight. I simply UNPLUGGED the scanner for 2 days, plugged it back in and now it works!!! So much for the high tech fixes !!!
  • Epson Master
  • 12,061 Answers
OK ensure you have the Latest drivers for your scanner, also check the Colour Depth that it is to be used with. Also ensure you have the latest Video Card Drivers installed and that OVERLAY is enabled. Of course check all ports and cables too.
Posted on Aug 03, 2007
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
Previews but does not scan
This appears to be a software problem. Run Scandisk/chkdsk on your Computer. Uninstall the driver software, switch off the computer & Reinstall the driver software and try.
S. Mohan
Oct 03, 2009 | Canon CanoScan D660U Flatbed Scanner
Scanner not working
Do you mean to say that while previewing the light moves and you are able to seek the preview, but the light not moving while you give a scan command?
If this is true this is something unusual. May be you have some hardware problem.
S. Mohan Chennai
Mar 07, 2008 | HP ScanJet 2400 Flatbed Scanner
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Canon CanoSacan D660U
uninstall the software then power down them restart then re-install software
Jun 03, 2007 | Canon CanoScan D660U Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 1670 Flatbed Scanner Logo
1,189 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
