Question about Coby DP-768 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Wood Frames
Full frame?? just need to know how to display the pictures in full frame. thks
  • exclusive123 Dec 15, 2008
    Why are you sending me the solution I solved???????HELLO
Hello to all. Well after a few tries I figuered it out, all you do is hold down the arrow pointing > to the right at the back and thats it full screen, I guess pressing the arrow < pointing to the left reduces the size again. Just remember to hold it down for a few seconds.Hope I was helpful, take care all.. Happy Holidays
Posted on Dec 15, 2008
Some of my stored pictures display upside down
You need to use a PC to rotate the images to a correct orientation, then put the images back in the photoframe!
Oct 23, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
Nikon Coolpix P100 how to get full screen playback - now has picture on top and odd graph at bottom
While viewing the picture, press the DISP button to cycle through the available views of the picture.
Dec 14, 2011 | Nikon COOLPIX P100 Digital Camera
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Dark pictures
All photo editing must be done on the computer before transferring the pictures. The frame will only display your images, not edit them.
Jun 06, 2009 | SmartParts SP15MW (092566981886) Digital...
I can't erase
Follow these instructions, but before you do, please be sure you have saved your images off the disk prior to starting these steps.
  1. Press Menu/OK to display the playback menu.
  2. Press Up/Down to select FRAME or ALL FRAMES. Choose ALL FRAMES.
  3. Press the Menu/OK button again while ALL FRAMES is selected to confirm deleting all photos.
Please select FIXYA, thanks.
Jan 16, 2009 | Fuji FinePix A500 Digital Camera
Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Digital frames will not hold more pictures
With a screen resolution of 480 x 234 pixels a collection of 480 x 234 photos would number into the Ka-zillions in number. Since this frame can display jpegs up to 10 Mega-pixels the number would, of course, be reduced significantly.
Nov 29, 2008 | SmartParts INC. digital frame. 7.0 in....
Coby DP-768 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Wood Frames Logo
168 people viewed this question
Top Coby Photography Experts
Torashi
richie46
Are you a Coby Photography Expert? Answer questions, earn points and help others
