Question about Kenmore 44072 Front Load Washer
Kenmore elite front load washer
My daughter hit the pause/cancel button and now I have a flashing time on my machine and nothing I do will stop it and the washer will not proceed to spin. can you help I can't find my manual
  • 67 Answers
Make sure they didnt lock the control panel if it just beeps when u press buttons that might be it. there is a button u can press and hold for 3 seconds to lock and unlock the control hope that helps
Posted on Mar 20, 2007
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
What does a f 54 code mean?
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite calypso model 11022086
FL means flood condiction..clean or replace your pump..
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44072 Front Load Washer Logo
126 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
