You need to go to this website and download all the driversfor your laptop as needed. These are only for the Dell laptopD600! I would concentrate mostly on the "Chipset" drivers. that should re-enable the board's Microphone input jack.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Rich Lilja
SOURCE: My D600 internal microphone goes out all the time-Help!!!
Check you BIOS settings. How old is your laptop and what version of Flash Player is on your computer?
SOURCE: dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
SOURCE: Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
is it an internal mic or is it an add-on?
