Question about Toshiba SD-K220S DVD/CD Player w/Built-in Hi-Fi VCR :
Records sound but no video on timed recording from charter cable
TV is connected to recorder which is connected to Charter. The timed recording is set for later recording but when playback occurs the next day we receive audio, no video and the recorder shuts the TV off in 7 minutes. Why?
The Video selector Switch on the back of the recorder is set to the left while the manual shows all connections to the right. Does this have any effect on recording?
patpatsh@charter.net
    Top Expert:
  • Toshiba Master
  • 70,346 Answers
DO U HAVE THE VCR SET TO THE CORRECT CHANNEL? THIS WOULD BE 3 OR 4
Posted on Dec 14, 2008
Screen shows nodata
Screen shows "no data found". ' Relias Connect
https://rlconnect.reliaslearning.com/thread/4943
Screen shows "no data found". 2153112 Sep 2, 2015 8:53 AM. Screen shows "no data found". 20 Views; Categories: Senior Care - Assisted Living, Home Health ...
Charter.net No Data Message on a Gray Screen
www.charter.net/support/tv/no-data-gray-screen/
Charter CommunicationsTV with grey screen displaying words - No Data. If you are seeing the words "No Data" on a gray screen on your TV, follow these troubleshooting steps.
Why does screen shows NO DATA even after tracks have ...
https://sony-paa-pa-en-web--paa.custhelp.com/.../why-does-screen-shows...
If the unit holds no data transferred from SonicStage, the screen shows NO DATA. User can playback the tracks recorded with the unit from HOME screen - Rec ...
Feb 09, 2016 | Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I have Moxi thru Charter Comm, How can I usa my PC to record a program on Moxi using Charter TV Listings
you could use a tv tuner pci card (prob 15-30$ at newegg)... i just run svideo from the moxi to the tv card and just use composite to watch tv (u will get a tiny amount of interference on your tv but it works cuz the moxi has video signal on both jacks all the time) then i just downloaded a program to record the feed... hope that helps
Jun 18, 2010 | Dell Computers & Internet
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
I bought a used Emerson vcr3002 without a manual and cannot get it to record on high channels. Do you know how to adjust this?
television companies block out recording on the higher channels, they want you to pay for them and not be able to record them. I use to install for Charter Communications Cable and thats what they did
Jul 25, 2009 | Televison & Video
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Panasonic recorder
Have you checked your cables? Start resetting one unit at a time until you isolate the culprit. Don't forget the simple unplug all units to let them reset. .
Panasonic DMR-EH55
Motorola 6416 DVR
Sony STR-DA5000
27 analog tv!
Sony 5 Disk DVD Changer
5 speakers
PC connected
You think I have fun when something hiccups? A software snaffu? Bad a/v cable? Loose speaker wire? By the way-my online support is getting better and better. Charter cable has live chat, as does Sony and Motorola. Good luck. Also, I can't think of a single setting I've changed with the Panny. other than assigning digital audio out settings. DEcoder setting? Your Panny?
817-230-4017 if you haven't fixed it.
Dec 09, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Toshiba SD-K220S DVD/CD Player w/Built-in Hi-Fi VCR : Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
