Question about Kenmore 71420 / 71421 / 71422 / 71424 / 71429 Gas Kitchen Range
How to replace igniter on Kenmore range model 71421
One igniter is not sparking and the manual says the cooktop is not removable. How can I replace the defective igniter if I seemingly can't open the cooktop? I tried lifting up but something is holding it down. Could someone please help?
  • bmwjerry Jan 16, 2009
    I have same problem with model 75501 (I think that's the model, it says 362.75501990 on it. I think it's 8 years old-- AMANA label but from Sears.
  • Anonymous May 05, 2009
    I have the same problem. Only the big burner won't ignite. Surely, someone must know how to address the problem. I have tried to open the top, but I too am uable. Help!
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 49 Answers
SOURCE: cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Posted on Mar 08, 2008
SOURCE: "Cooktop Locked"
We found the manual. Held the button down for 3 seconds and it turned off. Felt like idiots!
Posted on Jul 19, 2008
SOURCE: cooktop wont unlock
Press and hold the "Top" button for five seconds. It worked.
Posted on Oct 27, 2008
SOURCE: Converting Kenmore gas range to LP???
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
Cooktop range stove spark ignition does not work
Check the ignition button, it is very common as well for the sparking diodes to go out as well. Some model range stoves have replaceable igniters, some don't. Good luck!
Feb 26, 2017 | Cooktops
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
Replace cooktop
Igniter? Is this a gas range (cooktop) or electric? How about providing a model number; or a picture of your cooktop and the igniters you want to disconnect?
Sep 18, 2014 | Kenmore Kitchen Ranges
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My clicker does not work with on my cooker
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jan 04, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I do not get a tic..tic spark when I turn on the stove. No problem with the outlet either.
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
heatman101
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Gas range top igniton not clicking, gas come on when lit with a match
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 71420 / 71421 / 71422 / 71424 / 71429 Gas Kitchen Range Logo
369 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
