Question about Goldstar MV-1615 Microwave Oven
The fan starts up and runs on its own and we are cooking
The fan of the MV 1610 ST microwave starts up on its own when we are cooking on the stove top below it and have the oven on as well. The microwave is installed above the stove and underneath the cabinet. We are not running anything in the microwave at the time. It runs for a long time until we stop cooking on the stove top and running the oven. . Is there anyway to stop this from happening or shutting off the fan? the fan switch or off switch does not stop the probem. Thanks.
  • alamedaboy Feb 27, 2009
    I have a goldstar over the range microwave, model mvh1615ww, which has always worked fine. Yesterday, while roasting vegetables in the oven, the vent fan came on (normal). Now the vent fan will not shut off. The only thing I can do, is unplug the microwave completely. I understand this feature, and that it can take a while for the vent fan to shut off, but this goes on for a longer period of time than ever before. I plugged the microwave in a day later, and the vent fan comes on, no heat from the oven.
  • perickson55 Apr 06, 2009
    The fan won't go off on ours either. It went on when we were using the stovetop and the only way it will stop is if we unplug it.
  • Goldstar Master
  • 9,098 Answers
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Posted on Dec 15, 2008
Fan stays on without cooking or starting
Sounds like a door switch problem. Relays can stick too so tap them to release, they may need to be replaced
Nov 24, 2013 | Sharp R-1610 Microwave Oven
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
MV-1610 Runs but doesn't heat
That wouldn't be a resistor on the capacitor, it would be the high voltage rectifier diode.
It should read open on a continuity check. A shorted high voltage diode is a fairly common cause of a no-heat condition.
For testing, see: http://www.gallawa.com/microtech/diode.html
To order the part, and for other Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Goldstar MV-1615 Microwave Oven
Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 06, 2007 | GE JVM1542 Microwave Oven
Goldstar MV-1615 Microwave Oven Logo
533 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
