Question about Ryobi 3-piece 18V Drill / Circular Saw / Light Combo Tool Sets
Chuck is sticky
18.0 v ryobi drill. The chuck is difficult to open and close. I tried wd40 but it's not helping. I've had this drill for 4 yrs. What can I do to make chuck operate like it's supposed to?
  • 2,176 Answers
If the jaws are rusted that will usually help but you might also try something like 3 in 1 oil also. What I would look for is at the end of the chuck body where the jaws come out is the metal flared some? Then I can usually hold the chuck collar with a pair of gloves and slowly run the jaws in and out with the power of the tool some to loosen them up. DO IT SLOWLY and use a glove.Dave
Posted on Dec 21, 2008
  • 3 Answers
Look inside the chuck and see if there is a screw at the base. This may have gotten tigtened and is causing the problem. I had this same problem on another drill (not Ryobi) and this was the solution.
Posted on Jan 15, 2009
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
How do you Insert a Ryobi One+ impact driver drill bit?
don't think there is much to it. See page 4 in this manual
http://www.ryobi.com.au/Ryobi/files/e0/e029b72d-32ec-4e92-a555-2a3caac4fa92.pdf
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
Apr 28, 2014 | Ryobi Impact Driver Kit: 18-Volt ONE...
Chuck is stuck OPEN black and decker power drill
Try beating on the side of the chuck with a rubber mallet and then try and close.
Oct 25, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
Dewalt 14.4 Chuck will not open or close
You don't say if there is something in the chuck or if it is empty. If there is a bit in the chuck try holding the bit in a vice and gently tap the chuck off, you will probably find it ok then. Give it a quick spray with wd40.
If there is nothing in the chuck check that the left hand screw in the center of the chuck has not become unscrewed and screw it back in (Anticlockwise) it can jam the jaws.
If screw is ok then try spraying inside with wd40 and use a pair of grips or a wrench to free it.
If all else fails take it to a repair agent. You don't sat which model it is but there is one version that has and will only take a very expensive chuck so get a quote first. \it might just need a strong pair of hands.
Jun 07, 2012 | Dewalt Drills
Model # HJP001 Ryobi 12 volt cordless drill. Chuck is jammed, will not close. There is a screw down inside the chuck but it will not turn.
I just had the identical problem with my HJP001, and managed to solve it piecing together info from this thread. The cause for the chuck to jam was that the retaining screw had come loose and was interfering with the chuck. As others have pointed out, the retaining screw has a left-hand thread, ie reverse from most screws, which obviously needs to be taken into account. Simply tightening the screw solved my problem - together with some WD40 ;-)
Sep 05, 2011 | Ryobi Garden
Chuck is stuck open thank model973227070
Try spraying WD40 or similar into jaws of chuck and alow a couple of minutes for it to penetrate before trying to close it.
Also use cloths on the chuck while tightening to get a better grip.
Feb 27, 2011 | Craftsman 3/8" Corded Drill
I'm new to home improvement, and just bought my first cordless drill (Ryobi P204, 18-volt, 1/2"). How the heck do I insert the bit? The drill comes with two batteries, and a charger. There is an opening...
Like many drills these days, the P 204 has keyless chuck. In order to secure a bit, locate the forward/reverse switch (right above the trigger). Set it to the center of the three positions. This will lock the drill so that it cannot turn. Now turn the black portion at the front of the drill's nose (looking at the drill from the front, clockwise rotation will tighten the chuck and counterclockwise will loosen it) Adjust the chuck jaws so the bit you have chosen will fit without too much slop and then tighten the chuck until it holds the bit snugly and straight. Unlock the forward/reverse switch (push to the right to drill or insert screws) and you should be ready to go!
Oct 24, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Ryobi 3-piece 18V Drill / Circular Saw / Light Combo Tool Sets Logo
325 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
