Question about Jenn-Air JED8230 Electric Cooktop
Can't control temp of one element, is either high of off, nothing inbetween
The lower right element is either off or high. It can't be controlled to an in between temperature range. What is the problem and is it something I can fix myself if I get the appropriate part? Mike H.
  • jenair19348 Jun 28, 2008
    i replaced the grill with a coil cartridge. i am unable to control the temperature. Either it is off or high
  • Anonymous Feb 06, 2009
    Same thing . . . I replaced the grill with a two-burner coil top. I can control temps on one coil and the other is either OFF or HIGH. Any ideas how to fix?
- The infinite switch for the controller likely needs to be replaced, this part can be ordered from your nearest Jenn-air parts dealer
Posted on Jun 04, 2007
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
KDRS505XSS freestanding double oven range has wiring faults and will not heat. How do we fix them?
I would have this unit checked because the electronic control is 300.00 for this unit. I ran into this and the control was the fault not the wiring to the elements, but I can't tell you to change this because I won't miss lead you like that. Several tests need to be done to rule out a shorted element before the replacement of the control unit p#W10365424, most electronics are not returnable due to there nature of people swopping them and returning them. I think a service call is needed to be sure of the issue you have.
Good Luck
Mar 30, 2014 | KitchenAid KDRS505XSS
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
One of the heater elements would not turn off
switch is bad needs replaced
Jun 24, 2009 | Cooktops
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Jenn-Air Electric cooktop
did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
Dec 29, 2007 | Jenn-Air JED8430 Electric Cooktop
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
544 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
