Question about Toshiba Satellite A205-S4617 Notebook
Problem the problem started when i formatted my pc i had deleted the eisa unpartation which contain the win vista and drivers of my pc so please i need your help to get back my deleted partation it was 3 gb thanks alot
    Master:
  • 413 Answers
Insert the recovery disk and re install windows.
Posted on Dec 29, 2008
Dear sir. I have Acer Aspire M5640 Pc. I try to install Win vista . normaly Vista Dvd is booting.. and 2nd step masage will be coming load drivers - No device drivers were found . Make sure that the...
The rescue disc that can only be made on your laptop by your laptop contains the required drivers. The Vista DVD on has generic drivers and may have specific drivers missing.
Are you attempting a fresh install or are there fragments of an old troublesome system still there?
If there is fragments left, after checking that the rescue/restore data is no longer on the hard drive, format the drive first and try again. It should then work.
Mar 23, 2011 | Acer Aspire m5640 PC Desktop
I am having VGN 23G and it came with Vista Home Premium. Right now im using window 7. The os's is working properly. Due to 1GB of RAM using vista is a bit frustrating . All the drivers for VAIO VGN 23G...
All the VAIO Computers will be shipped with the Recovery partition in the Hard Drive. If the Hard Drive is not completely formatted, you can access the Recovery partition by pressing the F10 key for 5 to 10 seconds when the VAIO logo appears.
If you're able to access the Recovery partition, then select Restore C Drive option to restore the Computer back to the factory settings.
Let me inform you how to check the if Recovery partition is available.
Press windows+R key and type diskmgmt.msc and check if you're able to view EISA partition. If EISA partition is there, then the Recovery partition is available and you can access by pressing the F10 key at start-up.
If the EISA partition is not there, then the partition is deleted, then you can purchase the Recovery Discs for your Computer which may cost $15 to $35.
Jun 22, 2010 | Sony VAIO VGN-N110G/W Notebook
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
I want to downgrade my desktop acer aspire x1800 vista to xp pro everytime i run set-up it always showing me an error could not proceed,.
Most like ly the hard drive has a Vista recovery partition. That partition has got to be deleted. You'll need to open a command prompt and follow the guide very carefully or irreperable damage could occur.
Here’s the trick to delete and remove the EISA recovery or diagnostic partition in Vista. Before proceeding with the deletion action, make sure that at least a set of Recovery Disc Media has been created. Else, you won’t be able to restore your computer to working and factory default condition when any problem on PC requires reinstallation.
  1. Open a command prompt as administrator.
  2. Run Diskpart application by typing Diskpart in the command prompt.
  3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
  4. Then type in list disk and press Enter key to show all hard disk drive available.
  5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
  1. Type list partition and press Enter key to show all available and created partition in the disk selected.
  2. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
  1. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Oct 08, 2009 | Computers & Internet
New HDD = 80GB but, Bios sees >1TB unpartioned space.
Whenever you switch drives, you must access the BIOS and have it redetect the drive every time. Try the new drive again. Have the BIOS detect it. Use the Windows XP disk and do a full fomat (youll get an option to quick format it, but dont) If the format fails, then the drive is defective.
Feb 26, 2009 | Dell Latitude 110L Notebook
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Nov 01, 2007 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
