Question about HP Photosmart 735 Digital Camera
Flash Will Not Operate
The flash on my HP Photosmart 735 Digital Camera Flash will not operate even with fully charged batteries. Help! What are my options to get this resolved??
    Novelist:
  • 198 Answers
Flash doesn't operate from various reasons. Try to reset your camera if you find in the instructions manual a procedure like that. If it doesn't work here are some possible reasons. The flash works because a power inverter will charge a capacitor at about 350 volts. These are required to make a small lightning inside the flash tube. If the capacitor is damaged it will not charge, and the flash woun't work. If the invertor is damaged, it woun't charge the capacitor, and without those 350 volts the lightning inside the flash tube woun't go on. If the components that links the the camera's internal processor to the inverter circuitry doesn't work because of some failure to those components, again the inverter woun't work. Any shortcircuit or open circuit or imperfect contact can result in this. Even if the camera's firmware was corrupted in some way it could fail to instruct the camera to charge the flash circuitry. As you can see there are many reasons for that but only a service center can make the correct diagnostic. It isn't adviceable to dissasemble de camera yourself and tamper with the invertor circuitry as you are exposing yourself to those 350V. You may get some nasty electric shocks or damage other components. Therefore, I think the best aproach to this problem is to have it diagnosticated and fixed by a specialised service facility.
Posted on Mar 14, 2007
What does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Photosmart R707 Digital Camera
Will not flash; display says 'charging'...but flash will not operate. Camera will take photos with out flash.
Run self-diagnostics test - press flash button while switching the camera on. One of them tests flash.
Jan 18, 2010 | HP Photosmart R717 Digital Camera
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Nov 29, 2009 | HP Photosmart R717 Digital Camera
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Hp r927
Sounds like blown flash bulb.
Needs to be replaced.
Mar 19, 2009 | HP Photosmart 735 Digital Camera
MY DIGITAL CAMERA KEEPS SAYING CHARGING FLASH EVEN WHEN BATTERIES ARE FULLY CHARGED AND PLACED IN THE CAMERA
Remove the battery and push the reset switch for about 5 seconds. Reinsert the battery.
Dec 22, 2008 | HP Photosmart R707 Digital Camera
When using the flash, camera shows charging flash and freezes up the camera
I contacted HP tech, after trying several resets and other setting changes, I was informed that it would cost more to fix the camera then its worth - No longer under warnaty.
I can use the camera as long as I disable the flash.
Go out a buy a Canon, I did and its a lot better camera.
Aug 04, 2008 | HP Photosmart 735 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
125 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
