My sony world radio icf-sw100 wont turn on and i just put new batteries in it
  • goodman66 Jan 07, 2009
    On mine the screen functions, and the back light illuminates. However the on-off, and time change buttons do not work and turn the radio on. The reset button does not change anything.
    Even though it is a post-1997 model and so should not be affected by ribbon failure, I have taken it apart and inspected the ribbon and cannot see any damage, but no improvement on reconstruction.
    Any suggestions?
Chances are the metalic "dome" under each button in question has rotated slightly out of position. This happened with the Sync button on my post-1997 SW100. Sunddenly no Sync function and nothing about Sync on the display. The problem is easily remedied if you're into radios. literally. (A friend fixed mine.) I know several individuals who might be willing to repair your unit. E-mail me for names? paul-diehl[at character]uiowa.edu
WARNING: VERGE OF RANT
Whatever your do, DO NOT SEND YOUR UNIT TO THE SONY REPAIR CENTER IN LAREDO. I sent mine in for the Sync repair and had it returned unrepaired, with "corrosion" given as the reason. I then had an electrical engineer take a look and he correctly diagnosed the problem in 90 seconds. Took him another 30 minutes to complete the repair, which required no new parts or soldering. By the way, he found NO CORROSON WHATSOEVER anywhere in the receiver. And by the way number two, SONY LAREDO returned my receiver with major dmagage to the chassis. After three frustrating months, I was finally able to get LAREDO to replace the part of chassis they'd broken. (They 'd counted on me not taking before and after photos.) Totally incompetent, totally unresponsive, totally dishonest (they said they'd ordered a new circuit board from Japan when they hadn't), just north of outright fraud. AVOID LAREDO AT ALL COSTS.
Posted on Feb 19, 2009
Try to push the RESET button. There is a little hole on the back side of the receiver.
Posted on Dec 21, 2008
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
How do I set the. Time
With the radio off, press and hold the ENTER (time set) Key DOWN. On the right side, there are 4 buttons with arrows on them. The inside ones set the timezone that you are in, the outside two will set the time. I just checked this on my ICF-SW100 and it works for me.
Mar 04, 2015 | Sony Icf-sw100 World Shortwave Receiver...
My Sony icf-sw100 radio has a problem with the battery hinge which will not close because the teeth of the case has worn. Can anyone solve the problem?
There are two parts involve for that problem, its either battery lid that slides up and locks and other is casing where this lid teeth go to lock.
Part numbers of both parts are appended below..
390984101 .. LID, BATTERY CASE
X33685342 .. CABINET FRONT MAIN ASSY
Click above links to get price info, both are available in partstore.com
Hope these info will help you.
Thanks.
Dec 29, 2010 | Sony ICF-SW100S Radio
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Just need a replacement telescopic aerial for my ICF SW100. Thanks!
There are many types available in the market - now being scare - but you can suit one with the same mount and size.
Some of the earlier models of cordless telephones have antennaes that can suit yourr requirement. Also check for old model radios to swap if you find there are no choices in the market.
If the old one is damaged or broken then you can mend it with mild gas welding.
Sep 17, 2010 | Sony ICF-SW100S Radio
Sony Radio ICF-SW7600 intermittent working
These radios are subject to bad electrolytic capacitors. Need to replace them. Not an easy job but can be done for about 25 dollars plus shipping. Rod ( poikaa@yahoo.com )
Apr 14, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Need replacement antenna for ICF-SW55 radio
dear Sir, I need the battery compartmenr lid and tha antenne for sony icf sw 55. I hope you could help me with that..Waiting for your instructions..best regards.. tuncay bayer . bursa - turkey arnildabay@hotmail.com
Nov 18, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
My Sony ICF-SW35 AM/FM/SW Radio is not staying on-
Download user manual of ICF-SW35 Sony Radio from Sony Support and hope this will help you to turn on the unit.
Thank you.
Nov 19, 2008 | Sony ICF-SW35 AM/FM/SW Radio
Have a sony world band receiver ICF SW77 and can't get adequate reception in France. Any suggestions? Eithne Doy
Bon Jour!
Maybe a problem with antenna jack or possible capacitor problem. Contact me here .... poikaa(at)yahoo(dot)com
Jul 01, 2008 | Sony ICF-SW77 AM/FM/SW Radio
854 people viewed this question
 Grubhead
Grubhead
