Question about Kenmore 15944 Top Load Washer
Install the switch
Need help to install part number 350733 for the Kenmore model 110 4588290 switch
  • 145 Answers
Anthony, you usually need to pull the 3-sided cabinet off the machine to get that part installed. Some can do it from the top, but having the cabinet off is the easiest. You have to open the control panel up first, then unhook the lid switch connector harness, then pop out the two straps that secure the cabinet to the back/bulkhead. Now the while cabinet/top of the washer lifts away by tipping it up and forward towards you. Now you will see that lid switch bracket assembly you want to replace is easy to get at.
Posted on Dec 14, 2008
Kenmore washer model number 11026842691 will not go in to spin cycle
If the washer fills normally, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike.
This is the most common cause of the problem you just described. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. The part number for a replacement switch for the model number you listed is 3949238. The lid actuator part number is 350733.
If you have questions, or need additional assistance, please post back with your complete MODEL NUMBER and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jun 30, 2010 | Washing Machines
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
Machine most of the time refuses to go into spin cycle.
Please check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening and closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike (a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
Thank you for contacting Fixya.com
Aug 05, 2009 | Kenmore Washing Machines
KENMORE 80 SERIES MODEL # 25842400
This often appears to a more serious problem than it really is. The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949238) and the lid strike will be listed as item number 20 (part #350733). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine Model #110.91551200
The symptoms you are describing are a caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 11 (part #285671) and the lid strike is item number 20 (part #350733).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
Sep 13, 2008 | Washing Machines
Kenmore 80 Series Model 22832100
It sounds like you have a lid switch malfunction. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number as "110.22832100" and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949238). The lid strike is listed as item 20 (part #350733). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
This is a simple and inexpensive repair if you wish to accomplish this on your own. This total repair will cost you a little more than $40. Let me know if you suspect you have other problems. Sometimes the timer can cause certain segments of the wash cycle not to work as well, but this generally is a bit more expensive, and not as common. The lid switch is a more common problem, because of the repeated use it gets while opening and closing the lid. The switch just simply wears out. I hope this helps you.
Aug 29, 2008 | Kenmore 22422 Top Load Washer
Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
Apr 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15944 Top Load Washer Logo
165 people viewed this question
Sal De
fordexpert
Robert Rankin
