I have a syncmaster t220/t220g monitor, I have had it for about three weeks. It just started to dim on varous screens (random) not sure why.
    President:
  • 2,992 Answers
If the screen is getting dim to the point where you can't read it, it might be due an intermittent backlight. If this monitor is really only three weeks old, you might consider returning it to the store where you purchased it and exchange it.
Posted on Dec 14, 2008
I have the samsung syncmaster t220. had it for about 2 years and just recently it has started going blank. i can't turn it back on any other way than to reboot the pc. there is no warning that it's going...
Since it works for 2 hours it may not be cooling fan problem, neither RAM. Not at all the screen because it's okay after reboot. Most probably the Power circuit could be erratic.
Sep 15, 2017 | Samsung T220 22" Widescreen LCD Monitor
Screen goes black but leaves a very faint image. this happens at random times. turming the monitor off and then on seems to fix the problem for a short time
You are losing your backlight. The bulb is probably overheating and dimming out, when you shut it down, it cools off and will relight.
Oct 11, 2009 | Samsung SyncMaster 920NW Monitor
Samsung T220 Screen Flicker
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Computers & Internet Logo
374 people viewed this question
David Payne
David Payne
