848p-A7 motherboard Intel P4 Processor, system doesn't boot when swiched on
  • 781 Answers
Dude.. your problem may have different root causes..
in general what you want to do is the following:
1. make sure everything is seated properly and test
2. make sure your memory sticks are compatible to *********** board, installed in the right slot(s) and test again
3. make sure your power supply is working properly and power plugs are properly seated (use it in another systme or teste it with ps tester and test again
do you hear a series of beeps?, is there any video going to the screen? any errors??
uninstalled any new hardware you had and leave the system with the minimum to work. motherboard, video card (use onboard), sound card (use onboard) network card (use only onboard if any), mouse, keyboard. and test.
things to try before blaming the motherboard or the processor is to read check for bios updates or confim you're using compatible hardware for your mb, here's the link for the manual, drivers, updates from the manufactorer for your motherboard..
good luck.. post more details of your problem if you need follow up
Posted on Dec 14, 2008
Can i replace my p4 processor with dual core processor ( my system is 965z intel motherboard lenovo company)
the sockets for P4 and a dual core are different. you will have to replace your motherboard. getting a new desktop will be a better option.
Jul 10, 2014 | Lenovo ThinkCentre Computers & Internet
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
I have a Pentium 4, 2.66Ghz processor with 848P-A7 motherboard. I purchased hynix 2GB DDR400 SDRAM PC3200(2X 1GB RAM KIT) to replace my 512MB DDR. Why does it not work ? Spec Says that it supports...
Hi dont know why new RAM dont work, may be faulty. Go to
Let them scan your computer and they will tell you what memory slots you have and what memory you should be able to use
Jan 23, 2011 | EliteGroup 848P-A7 Motherboard
I have a 848p-A7 motherboard with a intel pentium 4 processor. I just got everything, set up the cpu fan, and etc. but whenever i try to start up the computer, the onboard speaker keeps going off. It's a...
1. Along beep on a motherboard indicates something is connected backward such a a fan or a data cable to the hard drive.
If it is the hard drive cable then you must have pin 1 connector turn around and therefore the mother board is giving a warning.
2. You may have a power supply failure that is the power supply is not giving proper voltage to the mother board.
3. Your ram chip is not properly seated in the RAM slot or in backwards.
4. The CMOS battery to the mother board need to be replaced.
Sep 10, 2010 | EliteGroup 848P-A7 Motherboard
848P-A7 motherboard will not boot. Had for years
This motherboard came out about the time when the bad cap's started being put in boards in China. You might want to look a some of the caps.
on the motherboard to see if any of them look bad. A lot of the motherboards I replace have had them . This is one of the symptoms of a bad cap. You might want to check out Bad for more on this.
I don't know how familar you are with electronics but in case you need to know a cap is the thing on the board that looks like a tin can. If you see any brown stuff comming out of the top or bottom ,or if the top looks puffed up that cap is bad,and you have just found your problem. The motherboard can be repaired or replaced.
May 15, 2010 | EliteGroup 848P-A7 Motherboard
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
GD8 motherboard
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
Sep 09, 2009 | Abit GD8 Motherboard
Msi , pc boot , HELLP
Seems like your processor is getting overheated.
Check the heatsink for proper installation, and if possible apply fresh heat release compound.
Also make sure the fan is working and correctly attached.
Please don't forget to rate this answer if it helps.
Jul 23, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Foxconn 661M03C-6L MB and Pentium P4 1.8GHz Processor
I suspect the issue is that the 1.8 uses a 400Mhz system bus speed, and the mobo likely only supports 533 and 800.
Dec 22, 2007 | Intel Motherboard
Elitegroup 848P-A7 Motherboard - Will not boot
I had this exact problem with a newly bought motherboard and it turned on fan turned but the screen was black, also I noticed once it turned on it wouldn't turn off, (Am wondering if this is the case with you) the motherboard was fine as it is in the other room now working away, so dont get rid of yours just yet. Most new motherboards require additional power to the processor from the power supply, through a four pin power cable, which should be availble with the newer power supply units having (number of pins for you motherbpard power supply) + 4 (which is the 4 pin J-connector) printed on the packaging. If this is connected and you are still having problems which for me was the case, then you will have to try a different approach. Cutting to the chase, the problem I had that produced similar effects of screen being black when the motherboard was powered on, was to do with my case. It was one of those flimsy aluminium foil types. I came to this conclusion by taking my motherboard out of the case and hooking it up to the cases power supply on an insulated surface such as a cork mat. It then was working fine. So I bought a good qulaity case with a new power supply just to be sure, hooked everything up and hey presto it was fixed. It turned out that enough power couldn't get to the board as the cheap case was shorting its supply. Hope this is of some help.
Nov 13, 2005 | EliteGroup ECS 848P-A7 (1.0) LGA775 800FSB...
Computers & Internet Logo
221 people viewed this question
David Payne
David Payne
