Question about Video Cameras
Eject a tape from my Sharp View Cam
How to I eject a tape that won't eject. I left it in for awhile and when I turn on the camera it says eject tape. When I push the button it won't eject. Is there another way to trigger the eject mechanism so I can remove the tape? i have an old sharp viewcam VL-E31 and the tape just wont eject. also, how can i put the tapes onto videos or dvds??
5 Suggested Answers
SOURCE: Eject a tape from my Sharp View Cam
Try removing the battery and reinstall it if you haven't all ready tried this
Posted on Dec 26, 2008
  • 1335 Answers
SOURCE: Sharp Viewcam VL-AH151U keeps saying "eject cassette"
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Posted on May 03, 2009
Testimonial: "Thank you very much!!!"
sonicboomele
  • 1557 Answers
SOURCE: the tape on my Sharp Viewcam VL-AH50U keeps
i think it could be the latching system im not sure if its electronic latch or spring start by looking there if its electronic latch take it in to a shop if its spring latcg maybe the end of the spring just needs putting back on
Posted on Apr 24, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a Sharp Viewcam
The chances are that a switchcontact or motor is not engaging, and the unit will have to be opened up to be fixed.
Oftentimes, with these older units, switch or relay contacts become oxidized over time, and fail. It sounds crazy, but one fix (without having to open the camcorder) is to give it a bump with the palm of a hand. I used to do withis with my old Olympus, and that's the only way I could get it to work, without spending a few hours taking it apart.
You can always go by a tv or camera repair shop and see what they think. Get an estimate before having it repaired, since it might be better just to upgrade.
You can contact Sharp for support here:
http://www.sharpusa.com/CustomerSupport.aspx
Good luck, and hope this helps.
Posted on Jan 02, 2011
Tape will not eject
sir,
If any of your electronics system not using for long period, remember this things( detach the battery or power source , take out cassette or memory card, if the unit use in built chargeable battery, charge it occasionally.
just connect to the power, you don"t power on your camera, the charging light will flicker then push the eject button, remember do not on the power of your cam, hop that this will solve your problem.
Feb 03, 2016 | Video Cameras
Cassette stuck in left side, won't eject
The mechanism transport need work to allow the unit to get back to the stop/Eject cam position. Without that the deck is not going to work. This is usually but not always due to a small rubber belt. That is not all that is needed but the primary reason for that failure.
Jan 14, 2013 | Audio Players & Recorders
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
My camera won't turn on, and I dong know what to do it charges both buttons turn red but it won't eject my disc the screen won't come on or anything
I have a DCR-HC32. I left mine out in the rain. It would not power on. There is a reset button on the side of the eject tape door. I held this in for 5-10 seconds, the camera beeped and I was then able to eject the tape. This was after I put the camera in the freezer over night since I left it out and it got wet. My touch screen doesn't work. I already bought a new camera.
Dec 20, 2010 | Canon DC100 DVD Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sep 11, 2008 | Sharp Viewcam VL-A10U Camcorder
Wont eject
try taking the two small screws out of the part that reads "do not push this part", this is how i got mine to eject the tape.
Apr 20, 2008 | Sony Handycam CCD-TRV68 Camcorder
Tape want come out
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Eject
Same problem here with the Samsung D963 (DV cam). I discovered that if you cycle the tape loader without a tape and then load a tape the gremlins leave. At least on mine, the camera doesn't stop for an eject anymore. Hope this helps veryone with this stupid problem. Now if I could just fix the damned battery life....
Jan 15, 2008 | Canon ZR85 Mini DV Digital Camcorder
Do i need a new cam???
You cannot tell if the switch for the eject is broken on the printed circuit boar, or the switch knob may only be internally broke unless you take the camcorder apart. I have seen just the knob break off inside and this know is only a few bucks + the labor, and thats what ia going to cost the most.
Jan 05, 2007 | JVC GRD-350US Mini DV Digital Camcorder
Video Cameras Logo
120 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
