Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Water will not shut off.
When I start th washer, water will run in. the water load {small large} will not stop the water. If I turn the washer off the water will stop. If I turn the water off manualy, and manually start a agitate cycle, every thing works until the water starts, then it will not shut off again, untill i do it by hand. Whats the cure? Thanks for yourn help. Barry
  • Te ammo Jan 17, 2009
    I have the same problem. My washer is a 80 sergies. Not stakable. Please help. thank you
  • Anonymous Feb 27, 2009
    My water will not cut off and even if I pull the knob out and turn it off it will still come out for a while before completely shutting off.
    Problem Solver:
  • 6 Answers
1st: check to see if the hose that the water comes out when it drains is higher than the water level in the washer.
2nd: It could be the plastic line that is inside of the washer that determines the water level.
Check the hose at the back to see if it's higher first.
Let me know
Posted on Dec 14, 2008
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
Washer over fills with water
There is a pressure switch with a long thin hose or tube attached to it. It is inside the washer and can be located with the back or the top removed. As the water fills, the pressure in the hose increases and the switch activates at a determined pressure, shutting of the water valve. I have seen bad switches and pinched or clogged hoses..
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 80754 Top Load Stacked Washer / Dryer Logo
59 people viewed this question
Sal De
 Brian Main
Brian Main
