Question about Rockford Fosgate Punch 300S Car Audio Amplifier
Car Amp I have a Diesel Audio NSX-11 Duel Channel Amp.. and it has 2 lights on it, a red and a blue. Well one day it stopped working so I changed both fuses so they're brand new, but when I turn my car on my amp lights up red but not blue. It clearly has nothing to do with my fuses, and all the wires are hooked up... Should I look back at my ground? or my remote work?
  • rw10689 Dec 17, 2008
    i fried my amp... i found out i took it all apart so nvm
    thanks everyone.
    Problem Solver:
  • 14 Answers
I'd try looking at the remote wire
Posted on Dec 14, 2008
How do i get my amp to come on
Some car amps have a separate turn-on wire which delays power to prevent speaker thump. You may have such a wire (or a connection) that needs to be connected to power up the amp
Dec 15, 2012 | Diesel Audio NSX-1102 Car Amp
Hum in amp
A hum in a car audio amplifier is a good sign of a bad ground. Double check your ground wire and make sure you have it connected to bare metal. If it has any paint or anything what so ever on it you need to grind the surface down to bare metal.
Jun 03, 2011 | Diesel Audio NSX-8004 Car Amp
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
What is the fuse box layout for 1986 Lincoln Town Car?
Here is a recap by fuse/CB:
1. 15 amp -Light Blue
2. 8.25 amp -CB
3. Not Usable
4. 15 amp -Light Blue
5. 15 amp -Light Blue
6. 20 amp -Yellow
7. 10 amp -Red
8. 15 amp -Light Blue
9. 30 amp -Light Green
10. Not Used
11. 20 amp -Yellow
12. 20 amp -CB
13. 5 amp -Tan
14. 20 amp -CB
15. 10 amp -Red
16. 20 amp -Yellow
17. 15 amp -Light Blue
18. 10 amp -Red
Do you have a problem with a specific device? Let me know and I may be able to tell you what Fuse/CB.
Jul 23, 2010 | 1986 Lincoln Town Car
My amp will not power up
try hotting your remote wire to your batter if it don't come on u will need a new amp
Jun 14, 2010 | Diesel Audio NS-1000 Car Audio Amplifier
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Rockford Fosgate Punch 300S Car Audio Amplifier Logo
94 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
