Question about Nintendo Wii Console
Internet i know my ip address thing but what is a SSID
    Problem Solver:
  • 8 Answers
Your SSID is essentially the "USERNAME" of the router... like my SSID is: wilson54g ... and i disabled the wep-key... hope that helped...
Posted on Dec 15, 2008
I need internet on my dsi
Well, have you done the homework?
1. DSI needs WiFi, ie, wireless internet. Do you have a wireless router or wireless modem router in your place?
2. If yes, have you enabled the wireless radio in the router. This can be done by opening up the router options by typing the IP Address of the router (it should be somewhere written in the router itself) and login. If you don't know the password, google your model number and you will get all information like default ip address, login etc. If possible download the manual from the manufacturer website and go through it to familiarize the options. (If you have an apple router, you will need "airport utility"..google).
3. Once logged in as "admin", look for "wireless" options (Manual will help you), enable "radio", "ssid", note down the ssid name, and for troubleshooting purposes, leave the security "off/disabled". Save/apply changes.
4. Make sure wireless "G" is selected or a mode thats compatible with wireless "G" (go through the options, mostly default option will suffice). If this is in another page, again, save or apply changes.
5. Reboot the router, wait for a couple of minutes till the lights for internet and wireless appears.
6. From DSI, search for available networks, find the ssid name that you have noted down and click connect.
7. Hopefully, it should connect, otherwise, you may have to manually enter DSI IP Adress, subnet mask (255.255.255.0), gateway and dns servers (both router IP Adress). If your router address is, say 192.168.1.1, then give dsi an ip adress 192.168.1.xx where xx is a number between 2 and 255. That is, what ever ur router ip address is, just change the last digits to anything under 255, excluding the router address. Now try again, hopefully everything should be settled.
8. Look into DSI manual to see whether it supports wpa/wpa2 security or just WEP. You may also have to take into consideration any other devices that connect to router wirelessy, like laptops, smart phones, tablets etc. If all of them supports wpa/wpa2, go back to router options and select that security, create password, write it down. Otherwise select "WEP" encrryption. (The point to remember here is the lowest common denominator, ie, if DSI supports only WEP, selecting WPA/WPA2 will be useless, as DSI will not connect, even if it sees the SSID.
9. Save changes, reboot router, wait for lights to steady.
10. From DSI, again select your SSID name from available networks (just to make things easier, shut down DSI, restart to disconnect earlier connections), it will ask for password or both password and security type. If DSi supports WPA/WPA2, and ur security is set as such, and DSI is not connecting, play with the options, if any, like "WPA only", WPA2 only" WPA/WPA2" and try to connect.
You should succeed with this much details. Good luck
Jan 15, 2012 | Nintendo DSi Matte Blue Console
When I connect my modem dorectly to my pc it works fine with IP address 192.168.1.33. When I go through My D100 I have no connection anf the IP has changed to 192.168.0.100 If I reinstall on dynamic IP...
Improve the Fixya.com experience for everyone by voting!
I think a functional explanation may be of some assistance to you.
The IP address is assigned to the server or client software, but not to the physical workstation which the software or device is installed.
D-Link and virtually every other provider uses IP addresses from a Private IP Address class, which is special class of IP addresses that is reserved for private local networks (not to be confused with Virtual Private Networks, or VPN).
The default IP address is 192.168.0.x and assigned automatically. The most common IP address in any local system is 192.168.0.1.
Over the years, I've found that it is unnecessary to manually TCP?IP settings unless the automatic settings or configuaration has failed When I do have to change the settings, the following are used on Local Area Networks (LANs):
IP Address 192.168.0.1
Subnet mask 255.255.255.0
DNS Do not change
Gateway IP
Address None because the default should be 192.168.1.0 or whatever was
automatically assigned.
Some additional information that should assist you in better understanding a LAN.
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share the same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues
Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jun 06, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I cannot get internet connection, i am on wireless 1 and it is asking for a password also i don't know the ip address, subnet mask and the dns
Even if the modem/router you are trying to connect to allow 'dynamic IP' address resolution (eg. no need for coonecting device to know IP address, subnet, etc...), you will still need to know the specific 'password'/ 'Security Key'/Encryption Key for your specific modem/router Wifi coonection - I am assume that you also know the correct SSID (Broadcast system ID for Wifi) for this Wifi Connection.
Hope it clarifies a few requirements.
Dec 27, 2009 | Apple iPod touch
Ip address
change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
Installing the compaq home internet appliance
does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house.
In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically.
the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses .
A subnet mask is usually 255.255.255.0 which is also needed.
Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this.
then type in ipconfig
press enter key
note the default gateway address and the desktop's ip address
you may need to enter the default gateway ip address into the fridge also.
if the desktop was 10.0.0.2 subnet mask 255.255.255.0
then make the fridge if manually have to set it
10.0.0.254 subnet mask 255.255.255.0
or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2
the first three numbers are called the network address eg 192.168.0
10.0.0
the last number 1 - 254 are individual address part
192.168.0.1 {router uses this 1 usually } to 192.168.0.254
Jan 16, 2018 | Compaq iPAQ Home Internet Appliance IA-1...
Ip adress
1. make sure ssid is correct
2. make sure ip is valid
3. configure proxy ( if you have one)
4. reset router and cross fingers
Mar 17, 2008 | Sony PlayStation Portable (PSP) Console
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Nintendo Wii Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
