Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
I have a homedics shaitsu back massager that stoped working
The blue light on the power button flahes on and off
  • 5 more comments
  • stevenlowell Dec 26, 2008
    I just opened the package. I hear a loud banging like it is jammed. I took the screw out first of course. The light blinks and I cant shut it off once plugged in.
  • cheeseball69 Dec 27, 2008
    I just had the same problem with the SBM-305MH Shiatus Massaging cushion. The twack freed it up and returned it to it's home at the base of your back, but it immediately did the same thing again. The shiatsu and heat mode worked, but it wouldn't roll up and down the back.
    Good thing we bought it from Costco.
  • symond Jan 16, 2009
    i have the same problem, it worked for a few times and now stuck half way with flashing lights, i have tried the thwack method, but no joy for me. unfortunately i bought it in the usa for $100 at costco and am now back home in the UK
  • stevess Jan 27, 2009
    rollers have stopped and the blue light flashes on the hand set, turning off and on or pressing any of the buttons has no effect at all
  • Justin H
    Justin H Sep 10, 2014
    noooooooooooooooooooooooooooooooooooooooooo!!! we all have the same problem, how do I fix the blinking flashing light? Is it just going to blink???? oh man, there goes 100 $ .. booooo
  • Olia
    Olia Jan 30, 2017
    I had the same problem. The chair was sitting there for a few years in a semi-working mode (it only worked for the upper back and the balls wouldn't roll down). Then I decided to give it a few knocks on the back, and voila
  • Bob Dixon
    Bob Dixon Oct 15, 2017
    Just had the same problem. Flashing power button, started thumping it but no luck. In the end dropped it on its back from about 4 feet, now working again.
    Happy days
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Posted on Dec 19, 2008
  • Scott Adis Feb 20, 2016
    aNOTHER PERSON CONFIRMED A NICE THWACK DID HIM WONDERS ALSO. THANKS
  • BDazzled Designs May 08, 2017
    I switched massaging cushions with husband because he said his was acting up. It kept getting stuck at the lower back in Shiatsu setting. Strange. So I just started it up on the Rolling setting and let it Roll up and down a few times. Tried the Shiatsu setting and now it's working. But I still have to start it up Rolling it up and down a few times first or it gets stuck again. Maybe that's what resets the mechanism?
I had the same problem with mine. I got it new & it wouldnt do anything when selecting the mode, it just made a click sound thats it.
I came on here & found where someone said to bang or smack the back of it a couple times & presto the rollers starded doing there thing, so I would recomend this 1st to anyone having a stuck roller or a unit that dosnt do anything after selecting the mode you want.
Its like an old 30's Ford you just gotta beat on it a bit to get it fired up.
Posted on Jan 19, 2011
We had the same problem with the flashing power button and it wouldn't do anything else except make noise
I unzipped the back which wasn't that easy because they tied all the zipper heads together I had to cut the threads
When I got it open I saw that a piece of foam had ripped off and gotten stuck in between the massage assembly and the lower contacts once I remove that it worked fine
Posted on Jan 19, 2018
    New Friend:
I had the same issue with the blinking red light on the power LED button for my Homedics 3D Shiatsu Plus massage chair. I used a standard kitchen spoon edge to unzip the back reverse zipper and exposed the internal workings. Then I proceeded to remove the three phillips screws covering the electrical circuit board box. I re-seated all of the electrical connectors and the unit functioned properly. P.S. You should always unplug the power cord before performing any steps mentioned above. This will prevent any electrical shock or damage to you or the unit. Be safe!
Posted on Aug 07, 2017
  • 1,828 Answers
Sometimes all kind of electronic products can have problems because of oxidation /or/ moisture after a while , but not direct after buy if some attributes are new then it can have a problem with their timing on gears but also with bad mounted or just bad type of microswitches , or a dirty mode-selectswitch or 1 broken tooth or the worm axle broken on a gear things or solderings that where not good mounted on electrical circuits, only to be shure open the whole equipment so you can see and measure ,find and repair the problem, if you be able to do, but if its a new product and repair is not addressed, no doubt immediately go for another model or brand. or go for money refund thats almost the best remedie
Much kind of shiatsutools can be bought as commercial trash.
Posted on Nov 15, 2016
    New Friend:
My back massager quit working after several years of soothing back rubs. After reading the suggestions here, I tried smacking it a few times to no avail then decided to really "whack" it, after all, I had nothing to loose since it was already broken. I placed it on a throw rug, so as not to damage my floor, and literally slammed the back into the rug a couple of times, plugged it in and voila! My back and I both thank you for this fix.
Posted on Aug 10, 2016
    New Friend:
Power switch does not work .it hasn't woked properly since new, but my husband who used it passed away and I have only just got around to trying to get it fixed who can help me please
Posted on Jan 30, 2015
I took mine apart and removed the white gear rack that the center contraption uses to move it up and down the back. I then moved the whole contraption down to the bottom and popped the gear rack back in and it allowed it to work again.. but it only goes up to the top and will not come back down. I am thinking the problem has something to do with the electric switch that tells it to reverse.
Posted on Aug 21, 2011
I was given a homedics percussion action handheld massager with heat. It won't work at all. It does nothing!
Check that you have power and that there is a lit LED when a massage attachement is put into the top. Otherwise check this link for further instructions and power issues.
The 3 Best Handheld Percussion Back Massagers Under 50 Back Pain Relief...
http://back-pain-relief-products.net/handheld-percussion-back-massagers/
Feb 09, 2015 | Homedics Health & Beauty
MCS-490H
Is it possible that there are differences in power sources between where you originally used your massager and India? The massager may have lasted just long enough in the new environment to fail.
Dec 10, 2013 | Homedics Shiatsu Massager
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this...
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Oct 02, 2017 | Homedics Shiatsu Massager
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
My homedics back massager with heat, stop working all of sudden, does it needs battery even though it has an electric cord.
the back massager with heat stopped working, bought a new power cord, still does not work, must be something in the back massager, but what to do ? ken
Mar 02, 2009 | Health & Beauty
I have a Shiatsu Massaging Cushion....it will not operate...blue power LED blinks.
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/massage
Jan 03, 2009 | Homedics Shiatsu Massager
Homedics programmable percussion massager with heat
The motor is Jammed
Try Taping it or banging it lightly
if that don't work im sorry ether needs repair or buy a new one
Regards; Aaron
Sep 15, 2008 | Homedics 10 Motor Back Massager with Heat
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
12,131 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
