Question about Microtek ScanMaker s400
Control panel is stuck on copy
The previous time I used the scanner was to make copies of tax documents. now when I try to scan something to save to hard drive I cannot get it to scan. the green "copy" indicator is at the top of the control panel but I cant change it to Scan.
  • 12,061 Answers
Hi, try this, remove any and all software for your scanner and THEN re-install the LATEST drivers, and software for your device. Once you have done so set all your defaults and hopefully you will find it is all working again.
Posted on Aug 03, 2007
What are the uses of a scanner?
Here are a few things you can do with a scanner.
Copying Documents - You can turn a good flatbed scanner into a copying machine by scanning in those receipts and other important documents and then use your printer to have a copy or just keep a digital copy. The best thing about this is that you could use software to improve the documents, if you need to take out a grease smudge.
Other things a scanner can do is copy a quick recipe out of Grandmas old recipe book, or a page from a magazine that shows the instructions for a new at-home project you have been wanting to do. Maybe there are some old documents in the family that you would like to have a copy of for yourself, those can be added to the computer files just as any other document.
Scanning Photos For Printing - Photographs are nice especially if you are a professional photographer, but you could use the photos for websites to display your latest DIY project. The images could be used for desktop wallpaper or sending to friends and family through email. Because they are digitized you can use computer software to edit them, and make interesting images on top of the first.
Here is something else you could do with a scanner and software. Using the edit feature you can enlarge your projects on the computer screen and then print out only that part. This allows you to make a full-sized pattern of anything you wish, turn around and use it to trace the object on plywood. Once you are done, cut out life-sized reindeer, cows, antique cars, you name it.
Faxing Documents - You can Fax a document that is already in your computer, but if that document is on a sheet of paper, you have a problem. A scanner can scan it in, then you can send it out by using the fax driver. When you have long distance relatives, and you find something in a magazine that they need to see, put the magazine in the scanner and then from the computer send them the information.
OCR - Optical Character Recognition (OCR) software is used to convert images to readable text. Once they are converted you can use a word processor to make the changes that are required. OCR software usually comes with the scanner.
There always seems to be a need to try getting a hard copy of some document or picture into the computer files, and a scanner is the only way to achieve that. Having a good scanner could really improve your home or office by allowing you to copy, organize and save important files and photos on your computer.
Mar 15, 2011 | Office Equipment & Supplies
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Canon mx320 does not scan
make sure that scan driver is completely installed in your computer.
To scan a documents in jpeg format, use the scanner icon in the control panel of your system. Insert your document in scanner bed then double click the scanners & cameras icon in the Control Panel.
To scan a documents and save in pdf format. just press the Scan button in the printer and save the documents in your computer once the scan window appear.
Oct 20, 2009 | Canon PIXMA MX310 All-In-One Printer
First time scanning
greetings.
To send copy of printed documents to others, follow the steps below.
1. use your scanner to scan your printed documents, save it to jpg format.
2. Use your email to send the pictures.
login to your email
compose or create the message
attached the images
send.
Hope that helps.
Jan 06, 2009 | HP Scanjet 4400c Flatbed Scanner
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Hp printer scanning prblm
Are you able to make copies only (just press copy color or copy balck and check)
And are you able to scan pictures.
If yes then make sure you are scanning from HP Director as Scan documents and follow the on screen direction.
If you do not get the option to scan documents then in HP Director go to> Settings> Scan Documents settings> You will see a option saying promt for these setting at the time of Scan> Put a check mark on that and click on Apply and ok and then try scanning document.
If this does not work the go to Start> Control panel (or Start> Settings> Control panel> Then printer and other hardware or Scanners and cameras> then Right click on the Printer icon> and scan from the options there.
Good Luck
Aug 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner not responsive. You can choose to have the document scanned to your PC but nothing happens and either location.
Hi, we need to check first if this issue is caused by the scanner it self or by the scanner driver. Please try the following to check if your scanner is physically functioning or not:
Basic Copying
1. Open the scanner lid.
2. Place your document face-down on the glass. Move your document about 0.1 inch from the top and side edge so your entire document is scanned.
3. Close the scanner lid.
4. Be sure the COPY button is lit. The default copy settings are displayed on the control panel.
5. Press the Color Copy button (for color copies) or B&W Copy button (for black and white copies). Your document is scanned and then printed.
Note: Depending on the copy settings chosen, your copied image size may not be the exact same size as your original.
If the image was successfully copied please uninstall the scanner driverm download the latest driver in http://support.epson.com and install it. Try scanning.
If the issue still present we will need to ensure the scanner is being recognized correctly. Have you had any other scanners installed on the computer previously? We would suggest checking the DEVICE MANAGER for any conflicts.
Get to the Device Manager by:
1. Right-Clicking on MY COMPUTER
2. Left-click on PROPERTIES.
3. Click on the HARDWARE tab, then DEVICE MANAGER.
In the Device Manager please for the following:
1. Any yellow or red X's, question marks or exclamation marks.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT.
To scan in paint:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FROM SCANNER OR CAMERA.
3. Choose COLOR PHOTO.
4. Scan.
It is also possible your Windows Image Acquisition (WIA) service is not started.
To start this process please follow the steps listed bellow.
1. Click on Start, go to Control Panel.
2. In the Control Panel window you will Performance and Maintenance, please left click that option.
3. Next we are looking for Administrative Tools, please left click on that option.
4. We are looking for the Services icon please left on that icon.
5. In the Services window we are going to scroll down to the bottom and look for the Windows Image Acquisition (WIA) Service, Please Right click it with your right mouse button.
6. We want to select the STOP option with your left mouse button.
7. Next we want to Right click on the Windows Image Acquisition (WIA) service again and select the START option with your Left mouse button please.
Tirzo
Jun 16, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Microtek ScanMaker s400 Logo
101 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Michael
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
