Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Blower won't shut off on heat or cool cycles
Honeywell Ct 3200 thermostat and Heil #NUGK100DH3 condenser gas furnace. Both are about 18-20 years old. Blower will not shut off after a heating or cooling cycle. I disconnected the green (fan?) wire from the thermostat and the fan continued to run. Could this be the thermal switch up in the plenum? ... or something more sinister?
Thanks, Dave
  • Honeywell Master
  • 3,087 Answers
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Posted on Feb 17, 2010
  • Rafael Martinez
    Rafael Martinez Apr 03, 2014
    What does afc stand for
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Own a heil gas furnace. The thermostat is set at 80. Is it normal for the heater to turn on and the burner to come on for 2 seconds, shut off then the fan blows room temperature air, then the cycle is...
Not normal. Is the thermostat located away from a heat supply vent (and direct sunlight)? If so, it will sense temp higher than it actually is, and shut off burner.
Sep 06, 2017 | Honeywell International Heil Quaker...
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Nov 01, 2009 | Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Furnace shutting on and off every four to five minutes all day
Have you had furnace cleaned? Have you changed filter or took filter out and try heater? Have you checked return grill to make sure you don't have anything in front of it. Return grill or duct could be blocked or two small. Blower motor could be going off on thermal overload. Does the heater do the same thing when it is 20 degrees outside. The other thing it could be is furnace is not big enough.
Good luck let me know what you find out
Jan 17, 2009 | Honeywell Electronic Programmable...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
530 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
