Question about IBM ThinkPad T42 Notebook
IBM Lapyop T42-message"Fan errors" does not turn on
My Lap top does not statrt. the Msg says Fan Errors
  • 558 Answers
Your cooling fan is reporting as damaged you need to replace the fan unit (cooling pad as well) likely service is required and unless you want to disassemble your laptop a service center would be better suited for this job.
Posted on Dec 14, 2008
Fan error displace on my t42 ibm.I noticed the fan is working but the error do come once in a while thereby prevent the pc from working
If the fan is running but your notebook still overheats, your computer will turn itself off, and you need to wait until it cools down
The question is, why is it overheating? Try using a vacuum cleaner close to the ventilation slots to suck out any dust.
If this does not solve the problem, please get back to me
Jan 24, 2014 | IBM ThinkPad T42 Notebook
Connecting to my home wireless
Does it find a signal? do you get an error message? if so what is that message. if it does not find a wireless signal do you have the the wireless turned on most of the IBM thinkpad has a switch on the side of the computer to turn the wireless connection on and off. make sure it is on. please answer the 2 question above for more help
Dec 13, 2007 | IBM ThinkPad T42 Notebook
My ThinkPad T42 cooling fan works slow... i feel like air flow is very slow when i touch the vents... i opened the laptop and checked the fan and it was really slow.. what should i do now please help......
You should replace the fan if it is defective.
You can check inside your Bios or System Setup to see if there are any options on controlling the fan. If the laptop is not giving you any error messages or overheating the fan might be ok.
May 06, 2012 | IBM ThinkPad T42 Notebook
Fan Error message but the fan's working on another machine
One option would be to replace the motherboard. You can use one from T40 -T43 with your monitor. I bought one on Ebay for $90 which came with the board installed to the bottom plastic tray. I only had to install my monitor, memory, keyboard, hard drive, & plastic bezel and I had a good working unit for $90.
May 15, 2010 | EliteGroup A530 Notebook
I get the msg below when I open my IBM T42 lap top connected to ho 5550 printer. The file'hpzrp306.dll'on hp cd is needed
To resolve this issue please disable the automatic start of HP Programs at start up. Please follow the instructions given below and verify the results.
  1. Click on ‘Windows Logo’ on your desktop.
  2. In SearchEdit Box type ‘msconfig’ without quotes.
  3. Go to Start up tab.
  4. Uncheck all the HP related items, except the entry which has the file as "HP Digital Imaging".
  5. Click on Apply to apply the changes.
  6. Restart the computer.
Sep 05, 2009 | HP DeskJet 5550 InkJet Printer
IBM T42 gave fan error, replaced and can not get it to reboot
make sure the fan is pluged in correctly and you didnt unplug anything else such as memory or etc or bump the cpu... did you put any thermal paste on the cpu when you put the fan on it? its needed to bond the too together to make a better cooling system there maybe a setting in your bios to disable fan monitoring or cpu temp etc have to look at your bios to see
May 27, 2009 | IBM ThinkPad T42 Notebook
IBM T42 gives Fan Error message and stops
The fan may be faulty or clogged with dust.
Check the fan to see f it spins freely and remove dust from the heatsink fins and fan assembly.
The specification in the manual for the T40 series shows the largest hard drive is 80 Gb.
It may be possible to install a larger hard drive, but check with Lenevo first.
May 25, 2009 | IBM ThinkPad T42 Notebook
Ibm think pad
File iertutil.dll is located in the folder C:\Windows\System32. Downloading the file and copying into the specified folder will solve this problem.
http://www.dll-files.com/dllindex/dll-files.shtml?iertutil
Sep 28, 2008 | IBM ThinkPad T42 Notebook
Turns off autometically
How far does it get on the boot process? Does it open the operating system completely before shutting down? Do you get any error messages, and does it go to a black screen stating Windos wasn't shut down properly? Answer these and I'll have a better idea of what's going on.
Aug 26, 2008 | IBM ThinkPad T42 Notebook
VGA port problem
That could be a video card driver issue. It seems that when the projector is connected, windows detects it a create another screen using up more memory. Try download a latest video card driver for your laptop http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1rd635ww.exe this is for Windows 200/XP for the IBM Thinkpad T42. If that doesn't work then you should also try updating your operating system. Hope that helps!
Sep 11, 2006 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
520 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
