Question about Crosley CR19CD CD Player
Crosley CR79CD CD Player
Hi, When I put a cd in my tray it won't shut and play the cd. Any suggestions? ChrisWy
  • dandjmom Nov 28, 2007
    Same problem. It started happening just a few months after I bought it.
SOURCE:
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
  • 42 Answers
SOURCE: Just bought a crosley CR250 I cannot open the CD player to put in
Your submission was incomplete. Please resubnit.
Posted on Jan 25, 2009
Grubhead
  • 5683 Answers
SOURCE: Hi I have a crosley auto rama record player with
There's one way to check the motor. Take it out and connect a battery (if it's over 9 volts a PP9 should do it.) if it don't turn it's dead!
Then try CPC online parts people.
Posted on Jun 02, 2010
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Cd drawer won't open
This is a belt driven tray transport- you need a new belt installed. I just worked on one for my aunt recently.
Dec 08, 2012 | Crosley Celebrity CR73-3 3-Disc CD Player
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
Crossley cd player won,t play cd
Try a cd cleaning kit and follow instructions, no change! the cd assembly will need to be replaced, considerable expence.
Jun 26, 2012 | Crosley CR-74 Shelf System
Tray #1 won't read cd most of the time
Hello
Insert a lens cleanig disc into the device and play it at least three times. If the fault is due to any dirt or dust accumulated on lasser pickup lens, thei will rectify the problem. If this does not help you, the laser pickup lens unit of your device should be replaced with same type and number. The lens cleaning disc can be bought from most of the electronic sparepart shops at your town, and won't cost more. OK.
Jan 29, 2012 | American Audio Mcd810 Dual Mp3 CD Player...
Own a crosley jukebox, cr-12-3. unit is not reading the cd's. any suggestions? i tried a cd cleaning disc. still nothing
Hi
if you can open the jukebox and look for the cd unit. under the place of the disc you should see the laser head its a small lense
try to clean with a qtips could be dust on the eye
it helped me when my cd player did not play
Hope it will help
Oct 21, 2010 | Crosley Jukebox CD Player with AM/FM Tuner
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Jvc xlmv33 three tray karaoke cdg player
TRY A LASER LENS CLEANER,,AND TAKE COVER OFF TRY BLOWING IT OUT ,,
May 12, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Jun 04, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Crosley CR19CD CD Player Logo
49 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
