Question about GE GSS20IEP Side by Side Refrigerator
Whirlpool will not cool
Hello. We have a Whirlpool Estate TS25AF refrigerator that will not cool. It sounds like an ice maker is trying to fill but the noise is in back by the compressor. The compressor is EGY 90HLP. Does this model have a capacitor? Could it be a starter relay or the compressor? Is there any way that I can check the relay? I am hoping it to be an easy fix rather than buying a new fridge. Thanks!! TIm
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
yalmer
  • 552 Answers
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Feb 13, 2008
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
  • 351 Answers
SOURCE: ice maker OK but water will not work? Whirlpool Estate TS25AF
hmmm, the only really way you will know if your water valve is working for the door is to jump it direct. unplug the machine get the valve out un do the line that goes to the door to the valve put a glass under the valve and jump it... if water then you have a door/control board issue.... no water than u need to replace water valve.
Posted on Apr 26, 2009
Can't find the drain on the freezer side of a ts25af estate refrigerator
found this..
https://www.youtube.com/watch?v=H_DKNtgd5vI
If you have a Whirlpool, Maytag, KitchenAid, Roper, Estate or Kenmore defrostable refrigerator, that is leaking at its bottom and building up ice, you may have a plugged bottom drain line. This video will show you how to unclog this line.
hope it helps.
Jan 21, 2018 | Estate Refrigerators
RS22AQXGW03 needs icemaker cleaned
Hello. Refrigerator manufacturers do not recommend any cleaner for use on their ice makers molds other then wiping the surface of the ice maker with a mild detergent. The coating on the mold can be damaged with caustic chemicals. If you are needing to clean the cube mold on this ice maker because it is flaking or has a mineral buildup on it, the best course of action is to replace the icemaker. Here is one that is fairly inexpensive.
http://www.ebay.com/itm/4317943-Refrigerator-Icemaker-Ice-Maker-for-Whirlpool-Kenmore-Kitchenaid-Estate-/151851282376?hash=item235b0aafc8:g:8v8AAOSw~oFXDl30
Jun 26, 2016 | Refrigerators
How to reinsert ice maker into 1992 Model TS25AF
You unscrew the srews holding the ice maker into the refrigerator. There may be 2 or 3. Then you should unplug any electrical connection, and saw on another site you need to remove the arm and install it onto the new ice maker. Then replace the new ice maker into refrigerator. There should be a different piece that's actually connected to the water input and then sends the water into the Icemaker.
Aug 31, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not producing ice...arm is down and you can fill frozen ice in ice maker slot...you can hear when water fills up ice maker...but no ice in the bucket
Hello, If the filter don't fix look in there to see if ice built up on top to stop the unit from turning to eject the ice . It usually will take a butter knife or something to break the ice built up that prevents it from turning ice out .
Thanks
Jul 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker OK but water will not work? Whirlpool Estate TS25AF
Apr 26, 2009 | Refrigerators
No ice
see if there is a device the water goes into then another tubes come out and goes to the ice maker, that middle part is bad.
Feb 06, 2008 | Estate TS25AFXK Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
327 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
