I know I'm connected to it but it has a blank (black) screen as if it were off. any suggestions out there? I tried disconnecting - cool starting - and connecting to another computer to no avail. My video application confirms that I am connected.
SOURCE: Blank screen
Well....that my friends, you've got a busted backlight inverter. Need to replaced a new one... Have a nice day!
SOURCE: My MAG Innovision Monitor went blank, only works if I stay connected to internet
I had the same problem. Luckily I was still in warrenty and I sent it back to mag and they fixed it.
This problem is very often caused by dry electrolytic capacitors on the inverter board. If you have some skill with soldering you could try to change them. When buying new ones ask for LOW-ESR capacitors for switching mode power supplies (SMPS) and 105°C, they are a little bit more expensive than normal electrolytic capacitors, but are designed for this aplications so they lasts more. Normal el. caps will also works fine so when you cannot buy LOW-ESR for SMPS use normal ones.
SOURCE: My 19 samsung computer lcd monitor problem
I had the same problem...apparently the Syncmasters have some caps that are known to go bad pretty often. They will show visible swelling on the top with the slits. If they are flat they are probably good. The 820uF was too hard to find so I used a 1000uF with the same voltage. I had two caps blown on two different monitors so be sure to check them all. Hope this helps. Check out pics on BadCaps.com
SOURCE: Samsung SyncMaster 940T. Suddenly went to black
The backlight is problem is caused by either a faulty inverter board or a faulty CCFL lamp.
Check out LCD Parts foe parts, service, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Testimonial: "Being pointed in the right direction is sometimes 90% of the solution!!! Many Thanks For The Compass!!"
