Question about Brother LS-1217 Mechanical Sewing Machine
Thread is bunching up on the bobbin side
Why does the thread keep bunching up on the underside of the material? I'm pretty sure its threaded right but I dont think the tension is set right for the bobbin. How do I fix that?
    Scholar:
  • 65 Answers
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
I think you might be using the wrong size needle, or thread for the material you are sewing... but the site might have a few more options.
Good luck and Happy sewing!
Posted on Jan 24, 2009
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
What is the proper tension number
here is a free manual for the machine
http://www.singerco.com/uploads/download/445_4830_4832.pdf
try using a new needle--make sure the needle is the right one for
the fabric
make sure the top thread has not come off the thread take up lever
try using a different bobbin
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
Dec 05, 2012 | Singer 4830
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
My machine isn't quite picking up the bobbin thread. It brings up the loop of the bobbin thread, but I can't pull the bobbin thread through the back of the machine - it's like the top thread (I think) is...
It definitely sounds like tension adjustments,m make sure the top tension is about 4 or 5, you should only just about be able to pull the bottom thread through with some resistence, if it is too tight slacken the screw about a quarter of a turn anti clockwise and test sew and keep doing that until you get it right.
Apr 01, 2010 | Singer 7436 - INGENUITY
My needle thread keeps bunching and llooping on the underside of the fabric. I have re-threaded the needle, adjusted the tension and cleaned out the bobbin case.
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correct
There is no standard tension for any machine to be set at. They start at four when they are brand new, however, after years and years the springs become compressed. You could start at four and then play around with it from there. If you are getting loops underneath the material, you are threading the machine incorrectly.
Jul 15, 2009 | Kenmore 15358
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Bobbin holder doesn't spin
Be really sure that the thread is threaded properly. Correct size needle for the material, and no cheaper thread. It does make a difference.
Aug 22, 2017 | White Sewing Mighty Mender WW100...
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
167 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
