Question about Brother HL-2040 Laser Printer
My printer won't print anything.
My printer will pull the paper through and eject it, but it doesn't print any words on the paper. I tried using multiple programs, but it still doesn't work.
  • Anonymous Dec 17, 2008
    My new HL-2140 will print Microsoft applications, email, UPS labels & reports, but just prints blank pages on Shazam Report Wizard which is my invoicing program. Both Brother and Mailware (invoice software) techs say there is no problem. Any ideas?
  • Anonymous Jan 05, 2009
    toner problem
SOURCE: Printer will not print on 12x12 paper. Just ejects blank page.
My printer can not print when i give a print command.
Thanks and hope to hear from you.
Regrads
John.
Posted on Nov 27, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 04, 2009
  • 4 Answers
SOURCE: Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Posted on Nov 17, 2009
SmartFix
  • 89 Answers
SOURCE: HP Laser Jet 1100 - Pulling Multiple Pages thru when printing
Just by Cleaning and changing the Pickup roller
Click here and Follow the steps.
Please rate my response!!!
Posted on Jan 29, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: HP Designjet 130 ejects paper
It sounds like you have a bad leading edge sensor. This causes the printer to not be able to track where the paper is. Replacement of this sensor requires a certain amount of technical confidence as you will need to disassemble a certain amount of the printer.
Posted on Apr 01, 2011
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
My Lexmark 7300 printer will not eject the paper all the way when finished printing.
Hi
Check the printer paper size for your printing application.
Adjust it to the qualities of the one you are using.
Mar 03, 2012 | Lexmark Office Equipment & Supplies
My Epson 1400 wont pull the paper through when I hit the print button. But when I insert a sheet of photo paper and hit outside printer button it will pull thepaper through but wont print
Hi
First off, the simplest solution is to try to clean the rollers of dust. If you can access the rollers, especially while they are spinning, this would be best. Get a damp cloth either with water or rubbing alcohol and wipe the rubber down, and retest your machine. Most of the time this is cause by the paper pickup rollers, which are made out of plastic or rubber, getting too dirty/slick to properly pick up the paper. Remove all the paper and the paper tray if you can. Using a long qtip, clean the rollers with alcohol. If that doesn't work, or can't be done with your printer, take all the paper out but one sheet. Spritz some alcohol on the bottom of that sheet and smear it out so it covers the entire width of the paper up about 2 inches. Then try to print a document that is a blank page. After either of these methods wait at least 4-5 minutes for all the alcohol to dry before trying to print again.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 15, 2011 | Office Equipment & Supplies
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My HP Office jet 6210
If the printer seems to be printing and ejects paper when a page seems finished, communication is happening, just no ink.
To see if it is an ink or printhead problem, take any Word document, highlight all text and change the font color. Then try printing it; I would try this with a few different colors to see if any part of the printhead is capable of producing visible material.
Oct 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Paper always on right when loading to be printed
Canon Printers are notorious for paper jams. Don't throw it out the window just yet, there are several solutions. Visibly check that there is nothing obstructing your printer (use a flashlight). A kitty may have hacked up a hairball (just kidding). Try a can of compressed air to blow out any foreign objects as well as turning your machine gently upside down to be absolutely positive nothing is obstructing the roller assembly. Next, open your Word Pad and type anything (like how much you are enjoying your Canon Printer Jamming and how you will recommend Canon Printers to all your friends), Use an A4 paper size 'POSTER PAPER' (the same size that you normally use (8 and one half inch by 11 inches) as this is thicker than what you would use. From your Word Pad, click PRINT, you will need to run the paper through several times and this will clean out any built up residue. If you do not have 'POSTER PAPER' a 'MAGAZINE COVER' will suffice (just be certain that it is the same size). After you have run your 'POSTER PAPER' through, load your regular printing paper normally and this should resolve your 'FANTASTIC CANON PRINTER'.
Oct 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Page Eject WHen Printing Word Docs
change the paper size in the printer properties for example to a4, or to lettersize.ehat the actual sizeis.or the problem is with paper feeder gears. try cleaning them.
Aug 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
506 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
