Home | kawasaki | 19.2V 4 Piece Cordless Tool Kit | Kawasaki 19.2 cor...
kawasaki 19.2V 4 Piece Cordless Tool Kit
Problem for kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2 cordless drill
By ben_stormsfa on Dec 13, 2008
Batteries all powered up, pull the trigger and ...nothing. Trigger was hard to pull, when unstuck, drill wouldn't operate from that point forward. Any quick fix??
Same Problem
Apr 07, 2009
-   I have the same problem and I think it is the switch - after taking it apart, smelled the switch and it smells like it burnt. Great drill for small tasks. would like to replace the switch - anyone know where one can purchase a replacement switch? -   Guest
Mar 07, 2009
-   Warning, take the battery out of these units. I had the same problems listed above, with the switch working inconsistently. Then, the other day, my wife heard the drill operating by itself in the other room. By the time she checked on it it was smoking profusely. The handle had melted. I am convinced that if no one was at home at the time, it would have caught on fire. Scary!!! -   Mcorn
Mar 05, 2009
-   I have a similar problem.I was in the middle of hanging a shelf. I swapped oiut the drill bit fro a philips head bit and my drill just stopped working. I didn't think that it was the battery because I had just drillled the pilot holes with no problem. I swapped out the battery just to try it anf NOTHING happens when I pull the trigger. I get an indicator light with both batteries so I really don't think that it is the batteries. I think that it is the switch. I have no idea of how I can fix this and if I can't find a way to fix it soon, this was the LAST Kawasaki product I am ever going to buy.-   reidy2
Feb 04, 2009
-   My Kawasaki 19.2 cordless when batteries are placed in charger there are no longer indicator lights and both batteries will not charge at all.
RichP
randep@ptd.net -   randep
Jan 08, 2009
-   Same problem here, it started out by not always working when you pull the trigger and even then would change speeds while drilling. However it served it's purpose for small tasks. Now nothing - tried both batteries and nothing at all. I do not recommend this drill to anyone looking for one. I really haven't used it all that much either, just misc. household tasks. I have a Portercable drill for my heavy duty tasks. If anyone has any fixes, I'm listening - can't hurt to have a cheap drill laying around for easy stuff. -   dalebondz
Best Solution
posted on Apr 24, 2009
Very Helpful)
ad90537
Rank: Apprentice
Rating: 100%, 5 votes
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #2
posted on Feb 21, 2009
Helpful)
mlee19
Rank: Apprentice
Rating: 94%, 4 votes
I have the same problem with my kawasaki drill. It has been always a great tool until one day the trigger was "stuck" and not matter how much force I used, it would not work. The strange thing was, I was using it earlier that day, no problem. When I came back a few hours latter, it refused to work at all and the trigger is jammed. Then I noticed a burned plastic smell coming from the drill. So from there I proceeded to take the battery out and open the drill. When I was finally able to take the drill apart, I saw that it has shorted out somewhere and the black wire to the trigger was completely burned up and all that plastic has melted all over the trigger causing it to glue together. Kawasaki needs to recall all drills they sold because of this potential problem that others may of experenced.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for kawasaki 19.2V 4 Piece
Questions and Unsolved Problems for kawasaki 19.2V 4 Piece
Do you recommend kawasaki 19.2V 4 Piece Cordless Tool Kit?
Answer
Answer
Where can you buy new batteries for a JCB cordless drill
Answer
I have two hand tools Black&decker drills / screwdrivers > KC 9018 and KC... (More)
Answer
I have had two cordless drill variable speed triggers burn up and render the tool useless (original... (More)
Answer
how do you connect the wire connections for the power switch?
Answer
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... ... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For kawasaki 19.2V 4 Piece...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
