My Stereo integrated hi fi amp is giving a crackle when output from certain devices - like a build up of static at intervals. It is quite old NAD amp - is this a sign of transistor failure, is it worth repairing and how?
    President:
  • 624 Answers
This sounds like you may have a lot of solder connections on the amp board and the power supply board to be resoldered. After a few years of using the unit they can get heat stressed and develop cracks in them. The sooner you get this fixed the better. NAD is a very good brand of stereo and in most cases they are well worth getting fixed. If the stereo is used for too long it can develope some component break downs that would cost much more money to repair.
Sometimes the static or crackle sound is just the volume control or other controls like the balance or teble or bass controls that just need to be cleaned with the proper type of electronic contact cleaner.
I hope this helps, have a nice holiday season,
Dave
Posted on Dec 13, 2008
STEREO HAS NO SOUND OUT OF SPEAKERS COMING FROM AMP
I suggest you begin by checking the integrity of the speakers and wiring. This is a fairly easy test to perform and I usually used a pp3 9 volt battery across each pair of speaker wires to ensure each speaker produces a similar amount of crackle and hiss as the wires are wiped across the battery terminals.
Once that test has been performed and found to be satisfactory it is time to connect the wires to the output of the device; radio or amp.
If there is no sound it will be because there is no output from the device. At this point before calling the repair shop it would be a good idea to read the instruction manual to ensure the stereo is being operated correctly.
Aug 10, 2015 | JVC Car Audio & Video
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
I have a NAD turntable. I have noticed that on occasions there seems to be a background crackle.. Thought it was dust at first !! Have swapped the connection over where the turntable plugs into the amp....
Either you have a poor earth connection or you are getting a lot of static from the records you play. The best way of getting rid of static is a spray you can get for cleaning records. Search on-line for Anti-Static Record Cleaner.
Jun 15, 2011 | NAD 533 Turntable
Definitive Technology Mythos STS SuperTower loudspeaker are a good match for a NAD M3 integrated amplifier?
For the most part, it depends on the power output of the amp and the requirement of the speakers. Its a good idea to have at least 10% more power at your amp than what your speakers require.Find out what those values are if you don't already know and that will give you a better idea
Jan 06, 2011 | Audio Players & Recorders
Nad c372 problem with left speaker output
Hiya, did you try to swop the inputs as well and see if the problem swops. Try that as the input could also be low. If so try change the cable.
If not there try cleaning out the balance pot with switch cleaner (have to open to that and only you are comfortable).
If thats not there then likely an internal problem and will have to send it in.
Best of luck
Jul 14, 2009 | NAD C372 Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Crackling power switch on NAD 3220PE
Hi, i would try flooding trhe switch with CRC 2-26 for a start. Itr may recover some contact integrity. A jerry rig solution would be to bridge the switch contacts and leave it on all the time(i leave my amps running all the time) or if as in Australia you have a switch on the wall socket use that,
OR purchase a new switch from here. Not sure how you would go through NAD, probably dont have any in stock as a spare these days.
or if that does not work out, I could get one to you through ebay. Used to be quite a common TV switch, but I also remember replacing then in Nad amps, many moons ago ;) I think I still have a one in stock myself, packed away from when I was a NAD service agent:)
regards
robotek
Nov 04, 2008 | Audio Players & Recorders
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
83 people viewed this question
 Grubhead
Grubhead
