Question about Honeywell HHT-145 Air Purifier
I moved my hht-145 honeywell air purifier to clean the carpeting around it. I plugged it back in and it won't start. It's about 6 months old and has worked flawlessly. Is there a reset button. I lost my manual and can't find one on the WWW. thx..gordon Illinois, USA
    Problem Solver:
  • 48 Answers
Check the UV lights under the filters. If they loosen slightly the unit quits working. Simple fix, did this myself one time.
Posted on Oct 27, 2010
  • jblytle0208 Dec 03, 2010
    I had to blow mine out with an air compressor. After checking everything else, this got mine going. I was VERY dusty in there.
Posted on Dec 20, 2008
No power
mine was having the same issue. its been broken for 2 years now. i jsut fixed it a few minutes ago. there is a button sensor behind the top filter. if its not pushed in all the way it wont turn on. my filter was in correctly, but the button doesnt appear to be depressed all the way. when fastening the back cover it locked in good, but was still slightly loose. those two things together means the sensor wasnt being triggered.
with your unit correctly assembled plug it in. while plugged in simply press the top of the back cover (where that sensor is) and the light should go green. i then taped it tight with a thin electrical tape as to not limit the airflow. it now powers on and works great.
hope that solves it for you
Mar 08, 2012 | Honeywell HHT-145 Air Purifier
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the...
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
Mar 07, 2011 | Honeywell HHT-145 Air Purifier
Honeywell HHT-011 Air Purifier red light will not turn off even after cleaning the filter three times.
For those who's red light will not turn off after cleaning. There is a little button by the red light indicator. Take a paper clip and hold in for about 5 seconds. Light will then turn off.
Jan 22, 2011 | Honeywell HHT-011 Air Purifier
Honeywell htt 011 air filter light won't go off
Thank you to MPODHOLA. After cleaning your Honeywell HHT-011, if the red light does not turn off locate the very small button under the red light. As suggested use a paperclip, hold the button for 5 seconds and this resets the system. Make sure the unit is on when you hold down the button. I tried it with the unit off and it did not work. Turned on the unit, held down the button for 5 seconds and the system reset. No more red light.
Dec 03, 2010 | Honeywell HHT-011 Air Purifier
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
Can you tell me the difference between the Honeywell Tower Air Purifier HHT-081 and HHT-090? From what I find, they seem identical.
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Jan 29, 2009 | Honeywell HHT-090 Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Honeywell HHT-145 Air Purifier Logo
905 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
