Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
PIP will not go off.
The PIP feature will not stay off. We reset it but in a few minutes it shows favorites under it. In a few minutes, the TV changes to the favorite chanel listed and then the pip pops up again.
Will show pip but no big picture
Posted on Apr 11, 2011
    Genius:
  • 1,199 Answers
Try unpluging the unit 5 min then pres and hold power button 10 seconds (this should reset ir!
Posted on Dec 13, 2008
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
I have a black square in the top left corner of my Prima TV when watching a TV show, but when I press the guide on our satellite receiver it goes away, but returns when I return to normal viewing.
Look on your remote for a function called POP or PIP, if you do then that must be turned off. It sounds like you do have it. If you don't see it then go into your menu under features or under that order, and look for the Picture in Picture feature. each manufacturer calls it something different.
Nov 17, 2009 | BenQ Televison & Video
I am using a universal remote and must have pressed a wrong button. I now have PIP and cant get rid of it. the tele is tevion Model TPDP42P
The procedure to remove it with the remote is simple, it's a single button on the remote that allow to toggle it on and off.
The PIP function on generic/universal remote is often not the same as on the original one. PIP is considered an advanced feature.
Unplug and then turn back the unit ON, after few minutes, say 30 minutes. If the problem persists, then toggle the buttons on the remote, unless send me a pic of the remote so that i could tell you the button.
Note - Sometimes, this is a problem in TV as well.
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | Televison & Video
Picture In Picture Feature
Hi LEE,
I just went over the specs on the 42PFL5603D. It doesn't have PIP. I'm sure the guy in the shop was confused with another TV.
There is a software upgrade for that model TV. It wouldn't give you PIP. But, It will fix some of the problems they are have with the TV right now.
Hope I answered your questions.
May 28, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Changing channels on pip feature
I THINK YOU HAVE TO TRY TO SOLVE THE PROBLEM WITH THE REMOTE CONTROLLER SHOULD BE  FIND A KEY FOR
USE PIP
Dec 06, 2007 | Televison & Video
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Apr 23, 2007 | Panasonic CT-36SL13 32" TV
Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
