Question about Maytag MDE2600 Electric Dryer
Noise when dryer is turning
I have model MDE 6657 BYW and when it is running it is making noises. I would like to know how to take the top off so I can take a look to see what might be making the noise.
  • 145 Answers
Hi Scott!
On this model there's a little work to do to get the top open.
1. Remove the two screws that secure dryer door hinges to the frame.
2. On the opposite side of the door frame there are two screws also. Remove them and the plastic parts the screws go thru.
3. Remove the door by pulling it off with the hinges still attached to the door itself. The door will come right off for you if you took out the right screws in step one and open it and then pull away from the dryer (This model has a reversible door, designed for the customer to easily do themselves).
Now with the door off, the entire front panel pops loose, it is "ninged" at the bottom by two clips. The whole front panel will lift right off. Set the panel aside.
At the top of the edges of the cabinet, there are two metal hooks, one on each side, that are held in place with a 5/16" screw (use a 5 1/6" nut driver to remove)
After you remove the screws on these hook brackets, remove the brackets themselves. They are hooked into the top on either aide.
Now you can lift the top off sir...
Please rate my answer if this is helpful to you. I need to work my way up to be able to help via chat...
Posted on Dec 13, 2008
Thanks for the info. on this dryer. I saved at least $200 by not calling a technician. My problem was simple to fix once I knew how to take off the top on the dryer. One of the plastic fins inside the tumbler came off so I had to screw back on from the outside of the tumbler. I was able to take the top off in 10 mins. and put two screws in to re attach the fin.
Thanks again and happy holidays.
Posted on Dec 14, 2008
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
My fridgidaire dryer has begun making a howling noise that turns into a grinding noise after about ten minutes of use.. have back top and front off and am running it now.. Its comming from the motor
If you are sure the noise is from the motor and you have the belt off and still makes the noise then replace the motor it has a worn shaft bushing..
Sep 29, 2016 | Dryers
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
What is a glider? My dryer has started making some loud noises and the cloth like material that goes around it in the inside has ripped into shreds. Is this what is causing the loud noises? How and where...
The gliders are a piece of hard plastic that set on the frame, the peice that holds the drum, their is 4 of them and they are on top of the frame, the felt liner is what supports the bottom of the drum on the fram.
Oct 02, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
Dryer making banging noises
try this web site repair clinic .com expert advice and you can order parts right from them
Apr 06, 2009 | Dryers
My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
Maytag electric dryer model #MDE 4916AYW
If your hearing a buzzing noise, motor.. If it sounds like the motor is running, could be a belt.
Jan 07, 2008 | Dryers
Maytag MDE2600 Electric Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
